Is it works for TriAxis? Rocktron MIDI Cable 5 to 7 Pin
KingPetrucci
the triaxis is 7 pin midi in
but my foot controller is 5 pin in (free the tone ARC-3)
is ok?
thank you
Authorized Boogie said:
If you're not using the phantom power feature, you only need to use a 5-pin cable. Thanks!
I'm sure my foot controller is no need the phantom power
but I want to know the triaxis 7 pin, which unit is for phantom power?
thank you so much
thank you so much
From the manual:
PHANTOM POWER: The coax power jack above the A.C. line cord can provide power to a Midi foot controller, through the 7 pin Midi
IN jack. This is accomplished by connecting an external A.C. to D.C. power
adapter of correct voltage and polarity for whatever type of foot controller
you are using to the coax jack on the rear panel of TriAxis.
Connect a 7-pin DIN cable between the Midi In jack on the TriAxis and the
Midi Out jack on the foot controller. This negates the need for a clumsy power adaptor on the stage.
NOTE: 7 -Pin DIN cable will not fit into 5-Pin DIN jacks. Check to see that your foot controller accepts 7-Pin DIN cables and is wired
to accept Power in this manner...and of the proper voltage match to TriAxis’ phantom power output.
thank you so much
From the manual:
my foot controller just 5 pin out :cry:
Right...so use a 5-pin from your foot controller to the Triaxis....you only need a 7-pin if you are using the phantom power!
you mean I can use 5-pin input the TriAxis 7-pin socket?
Yes. The extra two pins send power to the foot controller. The other five pins (technically only three) receive MIDI from the controller. A 5 pin midi cable will plug into a 7 pin midi socket with no problem, just make sure it's lined up properly
Wouldn't this be better
http://www.ebay.com/itm/262265965935?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
