broken triaxis - possibly dead
scoot_001
Melbourne Australia
Hi All
I sent my triaxis in for repair as it had the following issues with;
1. will only respond to even numbered patches and preset changes for example - changing to patch 05 will end on patch 06. Changing to patch 06 ends up on patch 06. same for all odd numbered patches.
2. a number of sessions such as DV, Presence, Bass, and one other would start at the desired setting and then after a second or two, go up to 10 - as if the key is being pressed.
This is happening even after a completely new face plate was installed by a Mesa authorised repair man. He spent time on the phone to the Australian distributor etc but they could not work it out.
I let it sit unused for the last 18 months. Tonight, I decided to fire it up and see how it was going. Now however, when I power it on, the 4 switch lights illuminate with the loop light and that is it. Nothing else at all.
I suspect is is time for a burial ... Has anyone see any of these behaviours before ?
Thanks. :(
same thing happened to mine in the same amount of time.
i started a new thread on it but found this.
did you fix the problem?
link to my post with picture..
http://forum.grailtone.com/viewtopic.php?f=5&t=72178
