Mono pedal in Triaxis effects loop.
StaggerLee
Hi.
My plan is to use Mesa Boogie Five-Band Graphic EQ in effects loop of Triaxis.
Problem is that it is mono pedal so I can only connect it to input A or B in Triaxis effects loop return.
And if I do that I lose other channel.. (when I connect to 2:90 I lose other side)
So my question is is it ok just to use one of these mono Y-cables:
http://www.visiosound.co.uk/cables-connectors-c1/audio-cables-c8/jack-to-jack-c37/livewire-1-5m-mono-6-3mm-jack-y-lead-guitar-amp-keyboard-splitter-cable-p1431
from pedal to fx return with that cable? or is there a better way?
EQ will go to loop cause there its easy to put on / off for different presets. (aka. put fx loop on/off)
edit. I just figured out that cause I have G-major 2 between Triaxis and 2:90 I can go with mono all way to G-major.
Which way is better? Do I "lose" anything if I use triaxis as mono all the way to g-major?
Is there any difference in anything if I connect g-major from Triaxis with 1 or 2 cables?
Hey SL...
Here is a way to connect your 5-band EQ in the FX for you to evaluate...
Place the 5-Band EQ in the SEND and RETURN A Jacks, Then use your "Y" cable on the A OUTPUT to feed both channels of the 2:90
I hope this helps
Seeya
Joe
