2:90 - Sudden Volume Jump
BlackBart
Maybe someone can point me in the right direction-
The volume will suddenly jump up either channel randomly. I know it's not the preamp, I switched preamps and the issue remains.
The power tubes don't have many hours on them.
Am I looking at a cap job? I have swapped the 12AX7s, could they be the culprit?
I'd suspect either the 12AX7s or the Vol pots. Mine did the same 2 years ago and it turned out it was the Vol pots. After replacing them all is golden....
Thanks Triaxstasy! I'm going look into getting them replaced.
Have you had to do cap job yet?
