Triaxis disassembly for display repair?
toddler68
I am attempting to replace a few of the LED displays on the front of my Triaxis, but getting the front panel loose is proving to be difficult. I did some forum searching and came up with a hit regarding disassembly instructions on tubefreak.com, but I can't seem to find them on that site anywhere.
Sooooo, does anyone know offhand how to remove the front panel? Can it be done without removing the graphic label from the front?
Any help would be much appreciated...
-tdlr
All I can say is... good luck, I talked about it with my tech once and he said he'd rather get electrocuted than have to replace TriAxis LEDs again. He didn't give me any details, but from that I assume it must be pretty **** hard and/or time consuming.
I had the same problem. It turned out that you dont need to remove the faceplate to get to the LED-pcb. See pictures.
