Quad reverb and where it is in the chain
frood
Can anyone tell me where the reverb sits in the signal chain? ie. is it before or after the FX loop? i assume it's after...
As much as after the effects loop would make sense, I do believe the reverb is before the effects loop and before the graphic EQ.
To be sure, you could test it by using the effects loop out instead of the main output, and change the reverb settings around.
interesting. thanks for the replies. i do like the reverb but it did sound a bit funny before some modulating effects. not bad exactly, just a bit weird.
I can understand that. I find it a bit odd, but I keep it way down. If I really want verb I'll insert an outboard unit in the loop anyway.
