Quad preamp- noisy reverb.
spikenet
Hi,
Just wondering if I should be concerned about the noise of the reverb. While not overtly noisy, when Idle I can hear it humming yet set it to 0 the amp is dead silent.
Is this normal when on about a setting of 3-4?
thanks.
Hi,
This is true for all Quads of a particular production series. The position of the reverb tanks (there are 2 in the Quad) are too close to the mains transformers. The only way to sort this problem out is to remove the top tank and re house it in a seperate rack unit as far away from the main quad as possible - obviously with extended Grey leads.
Hope that helps !
I have 3 quads - two hum with ANY reverb setting beyond ZERO and one doesn't - I'm yet to investigate the exact differences in reverb tank positioning that effects this.
Cheers !
Ed
Ed,
Thanks for that info, sounds like they need shielding or as you suggest removing into a seperate case.
I'm looking at getting a G-Major or similar and running reverb with that soon so might remove the reverb in the Quad completely.
cheers,
paul.
Ed Pitman said:
Hi,
Hope that helps !
Cheers !
Ed
Sorry for digging up this old thread. It's in the forlorn hope that somebody might have solved this.
I have a Quad which hums really badly with the reverb on. It's dead quiet without it.
