It is currently Mon Jan 21, 2019 6:51 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon Sep 04, 2006 7:31 pm
Hi All. I just bought a NOS V2 triaxis with the Rectifier circuit. So far, i'm liking the sounds but i would like to add a little low end. I tried the Dynamic Voice but even on 1 it scoops out too much of the mids for my liking (even if i put the mids quite high). I realize that this is not a plug and play instrument so i would like to learn from others with more experience. Is there any way for this to not remove all the mids from my tone?
 Post subject:
PostPosted: Tue Sep 05, 2006 11:42 am
Here's a tip. Don't use the Dynamic Voice. I could never get the tones I wanted from the Triaxis alone. You should get a graphic eq. I got a DOD 31 Band Graphic EQ and it's great! You can shape the Triaxis anyway you want. I highly recommend it. Set the DV to 0.0 and put the EQ either in the Triaxis' FX loop or right after it. Here's the one that I use. It's well worth the $129.99.
http://www.musiciansfriend.com/product/ ... sku=180108
Also, what are you using for a Power Amp? The Mesa/Boogie 2:90 Power Amp is designed for use with the Triaxis and has 3 special modes that can be used with the Triaxis, one is a "Deep" switch which gives you a deeper tone.
+Mike+
Mesas:
Dual RACKtifier
Mark II C+ Coliseum
Mark IVA Short Head
Studio Pre
Triaxis v2.0 w/ 2:90 Power Amp
Non-Mesa:
ADA MP-1 Pre
Gibson Duo-Medalist (30 watts) Late '60s
Marshall JCM800 (50 watts)
Roland Micro Cube
 Post subject:
PostPosted: Tue Sep 05, 2006 1:28 pm
I'm using a VHT 2:90 and it has a depth control (on 10). You think an external EQ is the answer? Do a lot of people do this with the triaxis?
 Post subject: Adding low end
PostPosted: Tue Sep 05, 2006 1:46 pm
I use very little dynamic voice (below 4) on my settings, but I don't take it all out. Use your ears as you dial it in.
I do use and e.q., but I generally use it subtractively, to remove bass frequencies below about 80Hz. I realize it sounds counter-intuitive, but I swear by this technique. I find the bass to be more responsive and less mushy/flubby if I remove those frequencies. This leaves more space for the bass player, too.
Though I know some people ridicule BBE's Sonic Maximizer, I use one to clarify my overall sound. It is not an e.q. device, by the way, but is a time-based effect that helps compensate for phase-cancellation, thus removing murk. It adds tight, punchy low-end much better than the Dynamic Voice does, in my experience.
- T
 Post subject:
PostPosted: Tue Sep 05, 2006 2:01 pm
Maybe i'll try an external EQ und experiment. I just thought too many things in the signal chain was a bad thing. With the EQ, will i still retain the clarity in my tone? Any tips on using an external EQ?
 Post subject:
PostPosted: Tue Sep 05, 2006 2:07 pm
I know James Hetfield has used an EQ in the FX loop with no DV and you can't argue with his tone lol.
I use my EQ to dip some of the mids (not scoop) and boost a little of the highs. Also, if I'm using my ovdersized Mesa 4x12 cab I'll cut some of the bass frequencies. Offhand I think they're 80, 100 and 125. I agree with Timbre Wolf that this makes the sound tighter.
You should experiment all the time. Experimenting never hurt anything. I mean, if you have 20 non-truebypass pedals all hooked up infront of your amp, of course you'll lose tone. With just an EQ added you should still retain the clairity of your tone. It all depends on how you set it. As far as using one, just hook it up in the Triaxis' FX loop and fiddle around.
+Mike+
Mesas:
Dual RACKtifier
Mark II C+ Coliseum
Mark IVA Short Head
Studio Pre
Non-Mesa:
ADA MP-1 Pre
Roland Micro Cube
Last edited by phantomlord2oo on Tue Sep 05, 2006 2:15 pm, edited 1 time in total.
 Post subject:
PostPosted: Tue Sep 05, 2006 2:14 pm
but here's my question when adding a grahic eq to the triaxis.....i am a programmer.... i love to create different kinds of sounds ranging to all out metal to laid back bluesy sounds etc.....I have concerns about adding an eq to the rig and having it set up one way and it not sounding good overall....and i understand that i could place it in the fx loop and only use it where necessary and here's the kicker....while i love owning a triaxis I'm not real fond of the sounds I'm getting out of it.....the lead 2 yellows are pretty killer but i have trouble getting good tight punchy sounds out of nearly all of the other distorted channels......most of them sound real "mushy" to my ears with almost no definition or they are too "crunchy" in a brittle kind of way.
to help some of you understand even further, what I am looking for but having trouble getting out of my triaxis is this....here are some of my favorite recorded guitar sounds of all time;
extreme- 3 sides to every story
van halen- fair warning
dokken- under lock and key
andy timmons- resolution
cry of love-brother
styx-pieces of eight
I am not naive and understand that these folks have many vintage amps and all kinds of mics and cabinets at their disposal and I don't necessarily want to "mimick" their sounds but I love the above mentioned tones for straight forward rock and roll...i also love eric johnson's and david gilmour's tones but understand that they are primarilly strat induced etc....and i dont play a strat.
i have a digitech gsp 2101 that I have used for years in the studio and love the tones I have squeezed out of that thing...i mostly used my triaxis live but now I am trying to use the triaxis in the studio as well and it seems that unless i am going to be recording completley clean sounds on the rhythm green or the next metallica album that the triaxis is struggling to meet my tone needs.....anybody got an opinion on this?
one last thing, if you want to hear some samples of the tones I have used recently with my digitech gsp 2101 you can go to the link below and download some mp3's to hear for yourself....i am fairly happy with those tones and you can hear they have some mids in them...but when i try to get that mid out of my triaxis it just doesnt sound good to me. any ideas or suggestions would be appreciated.
http://www.musicexe.com/wisdommp3.htm
Mark V
Recto Cab
https://soundcloud.com/masque13
 Post subject:
PostPosted: Tue Sep 05, 2006 2:20 pm
You'll lose a little signal integrity with each successive device, if you listen carefully. But some are much better than others, and the loss can be quite insignificant, especially for a live rig. I listen deeply to my gear's sound and response, yet I'm fine with using the eq on my Replifex for subtractive tone-shaping I described.
I use the subtractive eq after the Triaxis; pre-Triaxis eq will behave differently.
- T
 Post subject:
Would it be OK to run the EQ in between the preamp and poweramp?
 Post subject:
PostPosted: Tue Sep 05, 2006 2:25 pm
Yup, that'd be perfectlly alright. That's how I have mine wired up.
+Mike+
Mesas:
Dual RACKtifier
Mark II C+ Coliseum
Mark IVA Short Head
Studio Pre
Non-Mesa:
ADA MP-1 Pre
Roland Micro Cube
 Post subject:
Might want to consider which preamp tubes you're using in the Triaxis. Stock Boogie pre-tubes don't lend themselves to providing solid, chunky lows, in my experience. Here's a little help, to get you started, if you wish.
- Thom
 Post subject:
PostPosted: Tue Sep 05, 2006 2:30 pm
I put JJ's in when i got it.
 Post subject:
PostPosted: Tue Sep 05, 2006 2:49 pm
tonesofhome7578:
Maybe some sort of MIDI controlled graphic EQ is in order. I've never looked any of them up so I have no idea about any of them.
+Mike+
Mesas:
Dual RACKtifier
Mark II C+ Coliseum
Mark IVA Short Head
Studio Pre
Non-Mesa:
ADA MP-1 Pre
Roland Micro Cube
 Post subject:
PostPosted: Tue Sep 05, 2006 3:11 pm
If you read Timbre's post he doesn't really go into many currently made tubes. It would be worthwhile for you to read the posts as it may be a possible solution for your problem.
Arigato gozaimas!
 Post subject:
PostPosted: Tue Sep 05, 2006 3:13 pm
phantomlord2oo wrote:
tonesofhome7578:
+Mike+
Behringer makes/made a couple and I think Mark Tremonti uses them. Take that with a grain of salt because I think his tone is pretty bad.
Arigato gozaimas!
Users browsing this forum: Google [Bot] and 7 guests
