It is currently Sun Feb 18, 2018 1:06 pm
Post new topic Reply to topic  [ 9 posts ]
PostPosted: Mon Jun 18, 2012 10:26 pm
I recently get a triaxis and I don't know what power amp get.
I had a old Crown D60 to test it out, so far, it's sound so much in your face that it's almost too much.
Do you think it will sound better with something like a 20/20??
Or a 50/50 ?
Mesa :
DC-2
Caliber 50+
Rocket 44
2x12 Vertical Recto
Triaxis
50/50
Guitars :
http://www.Indieguitars.com
PostPosted: Tue Jun 19, 2012 12:16 am
Probably. The Crown D60 is a full range hi fi audio amp. While these work with guitar pre amps they are not really voiced as such. You'd probably find any tube guitar amp will work better. I've run mine through a Randall RT2/50 and now a Mesa 2:90 and loved both of those set ups.
Peace,
Joshua
Guitars: ESP LTD EC-1000, ESP LTD MH-307, Epiphone Les Paul, EBMM Axis
Pickups: Dimarzio
Amps: Mesa Boogie Triaxis, 2:90
FX: TC Electronic
PostPosted: Tue Jun 19, 2012 3:50 am
The 50/50 will provide more "balls" while the 20/20 will give more attack and aggressivity, but with less bottom.
PRS McCarty Soapbar with BKP Pigs90, PRS custom 22 with BKP Rebel Yell
Mark V Head, 1x12" Mesa 1/2 closed (EVM-12L)
Triaxis 2.0 noFat - Quad preamp
Deep modded 20:20 - Bias modded 50/50 - SimulClass 295
Home made amps/speakers/pedals
PostPosted: Tue Jun 19, 2012 6:24 am
I'll go for the 20/20 then , the triaxis as so much low end.
Mesa :
DC-2
Caliber 50+
Rocket 44
2x12 Vertical Recto
Triaxis
50/50
Guitars :
PostPosted: Tue Jun 19, 2012 7:04 am
What makes you say that? If you've been running it through a HiFi amp, it will not give a realistic impression of the Triaxis at all. A HiFi amp will exaggerate bass and treble. The Triaxis itself is no more bassy than any other hi-gain amp. The power amp is a bigger factor when it comes to depth. The 20/20 is pretty low on bass response compared to the bigger 2:90. The main reason to get a 20/20 is to keep size and weight down.
Triaxis v2 (no fat mod)
Mesa Simul-Class 2:90
Marshall 9200
Marshall JMP-1
TC Electronics G - Major II
Digitech TSR-24
Boss GT-6
Ground Control
Fender Stratocaster
Gibson Les Paul
Ibanez Universe
Ibanez RG1620
PostPosted: Tue Jun 19, 2012 7:40 am
The crown just a normal power amp, with a " flat" freq. response.
I think I will prefer the 20/20 because I have a lot of low end form my cab ( Marshall 2888 with greenback) and the triaxis can deliver probably more then i will ever need. If I even want more bass, I'm gonna switch back to the crown and sell back the 20/20.
Mesa :
DC-2
Caliber 50+
Rocket 44
2x12 Vertical Recto
Triaxis
50/50
Guitars :
PostPosted: Tue Jun 19, 2012 11:24 am
The Crown is a HiFi amp and not a good partner for a tube preamp. It's not a tube amp for starters - that means you have to be careful about cooking the input. The Triaxis has a very hot output. With a tube poweramp you can push the input pretty hard without cooking it. HiFi amps have, as you say, a flatter frequency response and a wide frequency range. A guitar power amp is more targeted to the frequencies that guitars use. It is more biased towards lows and mids. a HiFi amp will go both lower and higher than a guitar power amp. You can look at a guitar power amp as being better "tuned" to the Triaxis than a HiFi amp.
You have already tried the Triaxis with the Crown and you didn't like it. Why would you consider it again as an option? The 20/20 is a nice amp, but it can be a little thin sounding - depending on the music you play.
Marshall 9200
Marshall JMP-1
Digitech TSR-24
Boss GT-6
Ground Control
Fender Stratocaster
Gibson Les Paul
Ibanez Universe
Ibanez RG1620
PostPosted: Wed Jun 20, 2012 12:19 am
But you can consider a deep mod on the 20/20 whenever you're not satisfied with the sound.
I personnaly love it with all LD1 modes on the TriAxis, so much attack for old school european punk ! :twisted:
PostPosted: Wed Jun 20, 2012 5:07 pm
I recently picked up a triaxis and I'm using it with a Matrix GT800 power amp. Something else to consider. I wasn't sure how I would like it because it's not tube, but so far I have zero complaints, it sounds great!
my current rigs:
86 Mesa Mark III blue stripe simul-class limited maple combo - mesa thiele EVM12L 1x12
Mesa Triaxis - Matrix GT800 power amp - EarCandy Buzzbomb 2x12
Digitech gsp1101 w/ Control2 footcontroller
