I have a strange question.
I am currently running my 2:90 on one channel (due to a faulty "A"side that I can't afford to get repaired).
I would like to try the 6l6/el34 split.
According to eurotubes, I need to run the 34s in the outer sockets (old 2/90).
I was going to try and save a buck by only buying two el34s to run in the side I am currently using (being the other side is not working correctly anyway).
Do you guys see any problems with this?
Should I pull all power tubes from the unused A channel before I try this?
I guess my next question would be.
Should I be pulling the tubes from the unused side anyway to save on tube wear and tear?
Thanks.
Thanks.
