Running two Weber mini mass attenuators with the mesa 20/20?
natek
I was wondering if the two Weber Mini Mass (25 watts) attenuators were a fairly good attenuator to use in conjunction with my setup which is a mesa quad preamp -> mesa 20/20 -> 2x12 cab. I've heard other brands such as THD and Dr. Z airbrake were really good but I need something that's FAIRLY inexpensive. your thoughts on the Weber????
I use the Weber with my Fender Champ and like it. Haven't tried it with my 20/20 yet.
I also use the Weber Mass products (Stereo Mass and Standard Mass units) and they are great IMO. The set up you are describing would be cool...but I would go for the 50 watt units based on what I read at the Weber site...
"A note about the power level:
You should select an attenuator that can handle at least as much power as your amp puts out.
Amplifiers are generally designed to operate clean, and most manufacturers specify the output power as clean power. When you run the amp full blast, the output devices actually become more efficient because distortion is not considered. Under those conditions, the amp may be capable of putting out as much as 50% more power than its rated clean power. Be aware of that when choosing an attenuator, because the idea of using an attenuator is to run the amp full blast into power tube distortion and then controlling the level going to the speaker. If you are going to dime a 50 watt amp, you should choose a 100 watt attenuator."
http://www.tedweber.com/
B_6
I have a 50 watter you could buy off me for a decent price is you're interested.
Hey yeah, i'll be looking for a couple shortly. is it in good condition?? how much do you want for it?
