Down and out in LA
fiatlux
California
I have a TriAxis hooked up to a TC electronics G Major and that to a 50/50 power amp. My problem is that sometimes when I turn on the amp via a furman power conditioner it all lights up nicely, but no sound. I can see the leavels sometimes and at other times not. FYI- everything is hooked up as it should be, just to dispel any ideas of it not being hooked up to speakers.
I would like to see first if anyone here can help, before I try Boogie again. That option did not prove helpful at the time, but that could have been my explination of the problem.
Thanks
RJ
Sounds like yout GMajor is causing the problem, try it without it in the effects loop and see if it all works. If it does, make sure the default patch on the Major G is setup correctly..
