It is currently Wed Feb 21, 2018 6:08 am
Post new topic Reply to topic  [ 10 posts ]
PostPosted: Wed Mar 12, 2008 9:28 am
Anyone knows the exact modification that I have to do on a 20/20 to work with 230V.
I've bought one in USA but I'm in spain, so...
the only information that I've found in the forum is that I will need to change three links, the varistor and of course the fuses. what links? to what type of varistor? what fuses?
a lot of thanks guys!!
 Post subject:
PostPosted: Thu Mar 13, 2008 5:17 am
Three photos. 1. the 20/20 2. close up of the links 3. sketch from Mat at Mesa Boogie UK.
The varister (the green thing glued to the blue cap) I got from Boogie's UK distributor, it didn't have any markings on it. I can't remember what I did with the fuses other than they were changed to suit 240v.
Ian
Mk2C+ SimCl,Rev,EQ,EV,Export Transformer,Maple,
Mk2C+ 60W,Rev,EQ,EV,Imbuya
MK3 Blue SimCl,Rev,EQ,EV,Imbuya
Triaxis V2, 20/20, V-twin rack
Imbuya Open back Cab with EV
2 black tolex open back & 2 thiele cabs with EVs plus a Short Head Shell by GTS
 Post subject:
PostPosted: Sun Mar 23, 2008 11:11 am
Does this kind of easy mod to change from 110V > 230V also apply to the TriAxis?
 Post subject: 2:100
PostPosted: Sat Mar 29, 2008 4:28 pm
Is it possible to change the voltage to the 2:100 power and the pre recto from 100V to 220v?
Rectifier Recording Pre
2:100 Power Amp
2 Thiele 1x12" EV
Boss GT-8
Ibanez FGM guitar
Fender Strat guitar
 Post subject:
PostPosted: Sun Mar 30, 2008 7:45 am
a lot of thanks to PRS-Ian for the reply, now I am searching information about the european varistor. the american varistor is Sincera 20D201K
I had the triaxis and there isn't an easy way to change the voltage, I supose that you can change the transformer.
http://www.tubeampdoctor.com/product_info.php?products_id=868
In the 2:100, I always heard that the only mesa power amp that can do this conversion easily is de 20/20. so, change the transformer.
 Post subject:
PostPosted: Wed Apr 02, 2008 8:51 pm
Varistor needed is Boogie part #516275
 Post subject:
PostPosted: Fri Apr 04, 2008 4:26 am
Do you know the rating?
Ian
 Post subject:
PostPosted: Fri Apr 04, 2008 5:06 pm
Im afraid I don't. That's a Mesa/Boogie part #, they try and force you to buy off them instead of just telling you what part type and rating you need.
A Boogie dealer/distributor should be able to provide you with one, at a cost.
The only place i could find them online was here:
http://www.gemusikk.no/shop/default.asp ... dno=174095
and again, they don't tell you the exact spec of the part. (65NOK is about 8 euro)
 Post subject:
PostPosted: Sun Jul 27, 2008 2:15 pm
Hi,
I don't want to hijack this thread, but my concern is quite similar except I've just moved from France to Canada. So as you may be guessing I'd like to transform a 220V Mesa Fifty/Fifty into a 110V.
Do you know if it's possible? If so could anyone recommend me a good technician in Montreal to handle the job?
BTW, I also have a Marhall JMP1 that I may like to mod the same way. Any comments and advice about it?
PostPosted: Fri Dec 09, 2016 6:33 am
hmmm, Varistor - regular 275V varistor.
I'm wondering, if this conversion can be really so easy.
the factory diagram shows, tha there should be some capacitors added in EU Version
http://usr.audioasylum.com/images/4/44596/20_20_PowerSupply.jpg
On the 20/20 power supply boad in my piece there are even placements for capacitors. Unfortunately I don't know how to add fotos.
Users browsing this forum: Google [Bot] and 2 guests
