Amp/Rack road cases
David.W
Does you amp stay cool enough? Seems like they would heat up the racks a bit too, as there above the amp...
Anyone have one of these?
David.
David.
plenty of pro's use these kind of racks. It would be pretty easy to attach rear rack rails to the amp head section and mount a rack fan on there for extra cooling.
T
No temp problems in mine. The racks are quite insulated from the heat of the amp. If you leave it on for 6 or 8 hours (oops) it will get a little warm, but never hot. A fan isn't a bad idea, but I've never found it neccessary.
I had mine built by Mark at Rock Hard Roadcases.
