It is currently Sun Jan 20, 2019 7:57 pm
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject:
PostPosted: Fri May 11, 2007 1:23 pm
So
Quad > Effects > Poweramp (without any direct pre and power amp linking?)
'92 Quad Pre
'99 50/50
 Post subject:
PostPosted: Fri May 11, 2007 4:09 pm
4Draw wrote:
So
Yes, you got it. Let us know how it sounds as I am not familiar with the 50/50
Carol Ann OD2-100 EL34>
Scumback 2x12 with XH75, ASW70
 Post subject:
PostPosted: Fri May 11, 2007 9:58 pm
ursinus wrote:
4Draw wrote:
So
Will do! I'll test it out as soon as I'm home.
'92 Quad Pre
'99 50/50
 Post subject:
PostPosted: Fri May 11, 2007 10:49 pm
This tuesday or wednesday I'm going to be doing an A/B with two things: effects out vs. normal out, and my never replaced filter caps vs brand new ones.
 Post subject:
PostPosted: Sat May 12, 2007 9:22 am
Could you make some clips? Especially from the effects out / normal out A/B? You've got a 20/20, right?
(this is Mhgny_JP from JP forums btw)
'92 Quad Pre
'99 50/50
 Post subject:
PostPosted: Sat May 12, 2007 11:22 am
So, are the overall output controls disabled when using the send fx instead of the normal output? Do you control the overall level with the master pots? Last question: is it really safe to do this or could it damage something after long time use? thanks!
btw, I'm asking 'cause I own a studio pre...
It would really be a great thing!
MESA/Boogie Studio Preamp
MESA/Boogie 50/50
 Post subject:
PostPosted: Sat May 12, 2007 12:11 pm
I'm definately going to be making clips. I've got a 50/50. ytse_jam, it should be completely safe to run the effects out instead of the normal output.
 Post subject:
PostPosted: Sat May 12, 2007 7:36 pm
Mike B told me that there is no possible way to do damage to the Quad in this config. The master pots do become useless at this point though, but you can program your effects to adjust the overall volume fed to your power amps. This is also true for the Studio Pre.
 Post subject:
PostPosted: Sun May 13, 2007 5:36 am
thanks guys, I will try it next time at rehearsals!
MESA/Boogie 50/50
 Post subject:
PostPosted: Sun May 13, 2007 11:40 am
Yeah the overall output is useless but you can still use the channel masters. I have tried both my studio and Quad running via the fx send into my poweramp and it does sound a bit better, a bit....more, if you will.
 Post subject:
PostPosted: Sun May 13, 2007 12:22 pm
how about the low/line switch? does it affect the tone or is it purely a level control?
MESA/Boogie 50/50
 Post subject:
PostPosted: Sun May 13, 2007 12:57 pm
It's just the level signal control, I didn't have to switch it from where it was at on either unit, so it still sounds great. The only change, if you switch it, is that the volume is either fine or too low.
 Post subject:
PostPosted: Fri Jul 13, 2007 11:25 pm
Can the output be modded to be more like the effects send...so that the volumes work correctly?
 Post subject:
PostPosted: Sat Jul 14, 2007 12:06 am
send it in. It is the safest and best way. Man, I miss my Quad......
 Post subject:
PostPosted: Sat Jul 14, 2007 12:08 am
By using it this way, you are using one less stage of pre-amp tubes before going to the drivers in your power amp. I preferred to wire it this way because it was less compressed, much more dynamic..... 8)
Users browsing this forum: Google [Bot] and 6 guests
