I was finally getting around to test configuring my WDW rack with the first two amps of the three that I will most likely use, a Fillmore 50 and a MarkV:35. I will be adding a TC50 later once I have these two setup and working.
I am running a Volcano from Soundsculpture in the effect loops of each amp.
So as not to complicate the description, I will cut to the chase and not get into the detail of all the connections, since I am using 2 GCX's and 2 SM10's for switching and mixing.
When i run Chnl 2 of each amp in tandem with distortion, it sounds great no issues, nice and loud, lol!
But when I go to Chnl 1 of each amp in tandem, clean, I get a very weak signal, that at times can distort a bit if i strum some chords. It does not sound like the typical "out of phase" signal that I have heard before when I would run my LSS and MarkV:35 in tandem with distortion on Chn 2. I solved that issue using a buffer in the loop of the LSS, that was inserted in a loop on the GCX, that would reverse the phase when switching to Chn 2 on the LSS. The manual also states this may happen when running another amp together with the LSS, because of the tube phase inverter.
I tried doing the same thing on the Fillmore 50 with the buffer, but reversing the phase did not help. I found that if used the Isolated out of the buffer, the clean chnl 1 running in tandem on both amps would now sound "normal", full and loud.
To summarize, I can run Chnl 2 in tandem on both amps, with distortion, without the buffer in the loop of the Fillmore 50 and not have any issues, but need to have the buffer, using the isolated out, in the loop, when running chnl 1 on both amps in tandem, clean, so that I get a normal signal.
If you made it to the end of the post, thanks for reading! lol
Any ideas? Thanks in advance!
peace
peace
