I'm getting a wicked hum on my 90 Watt Mark V when I plug into the Slave Out, which I do *not* get when I plug into the fx loop send.
Besides the hum, the slave out sounds better for what I'm using it for than the fx loop output, and I also want to be able to this with the fx loop completely disabled.
I'm not sure why one is humming and the other is not. I'm going to try and change tubes and see if that makes a difference anywhere, but does this leap out as any kind of "AHA!" situation that anyone else has run into before.
The hum is annoying on the clean channel and just devastating on channels 2 and 3.
