It is currently Wed Jan 23, 2019 5:32 pm
PostPosted: Mon Mar 12, 2018 7:02 pm
Hi all.
I use a Nomad 45 using the four cable method with a POD HD500x. This has worked really well for many months but has recently stopped working.
Any effects after the Pod's FX loop don't work (eg, if I turn on a reverb, delay or EQ I hear no change to the sound), and if I use a patch with no FX loop (bypassing the Mesa preamp) I get no sound at all.
I have tried replacing cables - no difference.
Here's what aim thinking:
1, Is there an easy way to check if something is wrong with the FX loop? I'm thinking plug a cable into send, one into return and measure with a multimeter. What should I be getting?
2, Is there any other way to test if the FX loop has an issue?
3, Would the parallel to series mod I've read about on here be a possible fix?
Any help gratefully received. I've got a gig on Thursday and I'm faced with abandoning the FX loop and re-writing all my patches for 'front end' otherwise.
Thanks
David
PostPosted: Wed Mar 14, 2018 3:03 am
All sorted now. After changing V4 I discovered the Line/Amp switch on the POD was stuck in the middle.
Who'd have thought it?
PostPosted: Mon Mar 19, 2018 11:20 am
Cool. Glad you found out.
PS: What is the "four cable method"?
Lefty guitars: Gibson SG standard (1977) • Gibson LP custom (1979)
Amps and such: Mesa Boogie Mark IV-B • Mesa Nomad 45 • Peavey Vypyr Tube-60 • Effectrode Blackbird • Kingsley Jester • AMT SS-11a • Zoom G5
Users browsing this forum: Authorized Boogie and 11 guests
