Roadster FX Loop and Footswitch
Smashcube
Hey Guys! I have a question I hope someone can help answer or direct me to the correct thread.
I have a Roadster head that when using the footswitch the FX loop cannot be turned off. When the footswitch LED is off the FX Loop is still active. If I turn the FX switch to bypass the FX loop is out. In addition with the FX switch is on the LED on the footswitch toggles on and off, but the LED on the head stays illuminated. Has anyone experienced this and if how how did you correct the issue?
Thanks in advance,
Smashcube
