It is currently Sat May 26, 2018 5:16 am
PostPosted: Mon Mar 27, 2017 10:03 pm
So I am a bit of a tech/gear noob so if you could explain as simple as you can what a solution would be. My Mark 5 25 has a terrible hiss and buzz sound. If I hold my guitar still and hit no strings at all, over time the feedback will get louder and louder to the point where a man just can't take it anymore. I also hear small little chirps and buzzes coming from the amp.
This is the speaker my amp is plugged into
https://www.sweetwater.com/store/detail/MiniRectCabA
I recorded my amp with my phone so you can hear it here.
https://soundcloud.com/user-357558003/ampnoise
1)Now on the back of the amp there is a Lift or Ground switch, I have it on Lift. Would switch it to ground fix anything?
2) Am I in need of a noise gate pedal? Or not because it seems like noise gate pedals get rid of hum, which I don't have. I have more of a chirp/buzz electronic-y sound.
https://www.sweetwater.com/store/detail/SentryGate
Possibly it could just be a tube that needs to be changed.
PostPosted: Wed Mar 29, 2017 7:36 am
That sounds like electrical interference, or some other form of induced interference. When listening to that clip there is a very noticeable pattern to the sound.
Does the amp do this with nothing but the speaker hooked up (no guitar or pedals)?
Have you tried a different outlet on a different electrical circuit?
Do you use any surge protection/noise protection on the incoming AC line?
Is your cell phone on or very close to the amp?
The ground switch is for the Cab Clone output only.
Dom
'07 Roadster Voodoo modded
'08 Stiletto Deuce II
'10 Mark V
'01 Recto 4X12 Slant
'04 Recto 4X12 Slant/Straight
'74 Les Paul Custom
'95 American Strat
'12 Les Paul Signature T
Slinky's & Jazz III's
Voodoo Labs MIDI
==> NOMAD on Facebook <==
PostPosted: Wed Mar 29, 2017 10:58 am
I agree with Dom. It sounds like outside interference. Are there any dimmers or other digital items in the same circuit or near the amp?
