It is currently Tue May 22, 2018 8:03 pm
PostPosted: Sat Feb 11, 2017 1:00 pm
Hi all,
Im the happy owner of two Mesa Studio Preamps.
I read a lot of times that its best to use the Send to connect it to the poweramp (instead of the output, Mike B said it for example).
What would be the best setting on the Line/Low switch in this case?
Im not technical at all, so I have no idea what it does (and no, Google couldn't enlight me, only very technical explanations)
Thanx!
Mark IIC+
Studio Preamp
Studio Preamp IIC+ modded
50/50
2:90 (for sale, because it SUCKS!!)
Gibson 1984 Explorer
PostPosted: Sat Feb 11, 2017 7:32 pm
Line gives more headroom, that is, you have to turn the volume up using "low" to match it therefore turning up the noise also. Try both but I used line when I had a studio-pre. I found the main and recording compensated outputs to be more compressed sounding compared to send out which sounded very open and full. When I first got mine, I used it with my 1972 Marshall Super Lead and then I used my Mark llB through the return but then I tried it in the front end and was wowed big time by that tone. I ended up using it with a Simul-class 295 and a BBE 822A sonic maximizer between them through a Road Ready Mesa 4X12 EV loaded stereo cabinet.
JP2C, Mark llC++, Mark IV-A, Mark IV-B.
PostPosted: Sun Feb 12, 2017 8:31 am
Thanks for the info, really appreciated.
I've noticed that at home, the low-setting kinda helps.
Because that allows me to turn up the amps themselves (pre & power) quitre a bit more, resulting ofcourse in better, deeper tone.
Without torturing my dear neighbours.
I can not damage my gear right, with the wrong line/low-choise?
Mark IIC+
Studio Preamp
50/50
PostPosted: Sun Feb 12, 2017 10:37 pm
No damage will be done.
PostPosted: Mon Feb 13, 2017 4:07 pm
If you use line and get distortion from clipping the power amp input, switch to low. Otherwise, use whichever you prefer.
Mini Rectifier blue LED
2x Recto 2x12 Vertical
PostPosted: Wed Feb 15, 2017 5:38 am
Thanks guys
Mark IIC+
Studio Preamp
50/50
