It is currently Fri Feb 23, 2018 11:01 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Dec 02, 2016 9:48 am
Dreamtheaterrules wrote:
dlpasco wrote:
...pricing and ship date? I have some kidneys to sell.
Correct me if I'm wrong, but since I kind of like having your around, I figured I'd better share my medical expertise. I think you had probably only better plan on selling ONE of those kidneys. Better sell it while they're still worth something. :mrgreen:
To be fair, he didn't say they were his kidneys. :mrgreen:
PostPosted: Fri Dec 02, 2016 11:14 am
Sweetwater demo is up:
https://www.youtube.com/watch?v=gjYyOcQ7oeg
Mesa Mark V
Mesa Mark V:35 Combo / mc90
Mesa TC-50 Head
Mesa Mini Rectifier 1x12 cab / v30
Mesa Thiele 1x12 cab / Fillmore
Mesa 1x12 Widebody open back / mc90
Mesa 1x12 Widebody closed back / mc90 x2
PostPosted: Sat Dec 03, 2016 4:45 pm
sloanthebone wrote:
Thanks for posting that. That sounded really great. When he turned the gain up on Hi, my heart went pitter patter.
My Humble Music Tech Blog:
Dual Rectifier Index
PostPosted: Mon Dec 05, 2016 2:13 pm
I'm going to have to order one before it's discontinued, just like my Dyne... ;-)
__________________
Mostly Fenders with Duncans
PostPosted: Mon Dec 05, 2016 6:22 pm
I went and played the TC yesterday. As far as I know it's the only one in my country until early next year. It was the head version and was paired with a 2x12 horizontal recto cab. I'm really excited about this amp, feature and tone wise it's what I have been wanting.
The TC is no ED2 in how it's sounds. It may have started with the ED , but the RA is much closer. The addition of a presence control for each channel in conjunction with the treble allows great shaping versatility.
Clean channel is great and much like the RA, loads of bass , but the presence allows sparkle to be added without making the treble harsh. The drive mode opens a new bag of low gain edgy tones.
Channel two is a real winner for rock and covers a surprising wide range of gain. Definitely more gain the the RA Lo mode and wider range of the control.
While I'm not a metal player Channel 3 has a totally crushing amount of gain and is great with for solos.
While this all sounded great with the master and output at about 12:00 I was curious to see how much the power section really had. Wth the output which is really the overall master volume cranked it scared me how much headroom the clean channel has. I don't think volume will be a problem for many people , but some may just prefer the way a 100 watt amp sounds and reacts. Perhaps there will be a TC100 at some point.
I have enough 100 watts amps, but am wanting a lighter combo amp. It does looks like the Tc50 1x12" could be perfect for me. I'm no longer looking at the Mark Vs. I loved the way the Mark V 25 sounded, but it didn't quite have enough power and has clean and crunch on channel 1. The V35 solved the power issue, not the channel issue.
Looking forward to trying the combo when they arrive.
Triple Crown 50 combo
Electra Dyne and Royal Atlantic heads
Express 5:25 1x12 combo
JCM800 2203
Deluxe reverb reissue
Traditional 2x12, 4x10 and 23" 1x12 cabs.
PostPosted: Mon Dec 05, 2016 6:31 pm
Thanks for the review. I'm really curious about this amp, as well as how it might compare to my JP-2C.
Mini Rectifier blue LED
2x Recto 2x12 Vertical
PostPosted: Mon Dec 05, 2016 9:49 pm
I should have mentioned that I used an SG and a Suhr classic pro to test. A guitar with high output pick ups would be brutal.
Can't really make any comment about the JP2C as I haven't tried one yet. One would think that the two graphic eqs on the JP2C would Make a big difference. The TC certainly won't be able to dial a classic "V" eq curve with the endless tweek-ability. Will be interesting to hear what others think...
The TC has the small reverb tank which looks similar in size to the V25. I was surprised to see the small tank, but overall the reverb is a good improvement on the RA which most people didn't seem to like. Like the V25 the reverb is very nice sounding even if it isn't quite a full as say the Lonestar or ED. Having a reverb control for each channel is a good thing too.
Elvis, like we have previously been talking about a big bottle lunch box amp vs EL84, the TC is pretty much it. Not quite lunch box size or weight, but the short head would still sit well on the Horizontal 2x12.
JCM800 2203
PostPosted: Mon Dec 05, 2016 11:03 pm
Did you happen to lower the master volume to see if it retained the tone you liked at low volume?
Mesa Mark V
Mesa TC-50 Head
PostPosted: Tue Dec 06, 2016 12:03 am
Yes I did try to lower the volume to see how the tone is effected. I tried first with the channel masters and they did seem to thin the tone out in a way I didn't like so much. There does seem to be a sweet spot around 12:00. The output control is more neutral, but the tone does still change. With a bit of adjustment of the tone controls I did find tone that I would be happy to use. Undoubtably some of that is down to hearing perception and probably speakers that were no being driven as well as Dow the amp responds.
I'd probably sum it up by saying the TC excels from normal to very loud, but is still good at quiet. Given I spent about 45 minutes on the TC my opinion may well change over time, but i think my RA100 does a little better quiet. The ED is definitely further up the scale with volume and sounds great at loud to ear bleeding levels.
JCM800 2203
PostPosted: Tue Dec 06, 2016 3:31 am
I just spend four hours with the amp using my Les Paul with JB.... Into a recto 2x12 cab. I checked out the entire range of what it can do.
Much easier to dial in and to get to know than most Mesa amps. I thought it sounded great and would have zero problems doing a gig with it. It has that upper midrange punch you expect from a 50 watt EL34 amp with some juice on the plates. Punchy and aggressive.
This is a completely new voice for Mesa. I had no problem dialing in any range of gain. The lead channel is fairly compressed. Rhythm channel being a bit more dynamic and not as midrange heavy.
The cleans sounded great to me.... Better than I expected. In the Mesa Mark / Fender family of sounds. I had no problem getting plenty of headroom.
The rhythm channel got pretty highgain.... But much less than the lead channel.
The dynamics were pretty good in this channel. I am accustom to using Fryette often. Most amps just do not have the dynamic range. I could not get it down to clean with highgain with the guitar volume.... But got some good blues tones.
It is a crunch channel. But is not voiced like a Plexi or 800. With the tight switch on I could get it closer to that sound. But it is more saturated and compressed like many Mesa amps. Ît is darker ..... I see the plexi as a fairly bright amp. You could get similar.... But the feel and tone was always different. You could get a modified English crunch sound no problem.
I could see why they say the lead channel is a mix of Rectifer and Mark. It certainly has that easy to play lead feel the Marks have. With the tight switch on it almost reminded me of a boosted Rectifer. The overall sound is smoother.... But still hairy. Below about 1 o'clock on the gain the sound stayed pretty focused. Above that it got more of a Rectifer highs.
Easy to get scooped or midrange heavy sounds from any channel.
Keep in mind everyone I only spent a few hours with the amp. I feel most amps take several days or more to really get to know. This amp was easy to learn.... But take what I say within the context of my experince. I don't think I know it enough for a full review.
The fact that Stephen appears from nowhere, is sentenced to death in an emotional public trial without anyone interfering at all and is then altogether forgotten as if nothing happened, is already suspicious.
PostPosted: Tue Dec 06, 2016 3:08 pm
THAT MAGNIFICENT BASTARD RYAN BRUCE GOT ONE AND POSTED A DEMO https://www.youtube.com/watch?v=gBuk9Egfm3k
Mark IIC+, III, V, Recto Reborn, TC-50
Sold: JP-2C, V25, Road King II, Tremoverb, Electra Dyne, ROV25
Twitter:mammothguitar
PostPosted: Tue Dec 06, 2016 6:31 pm
OK, kids! TC50 has its own forum now.
