Rectifier cabinet question...
dazed1
I have a Rectifier 2x12 cab with two jacks on the back, on is input the other is parallel out. I recently damaged the input jack. (don't ask) As I don't run any other cabinets besides this one, is it possible to use the parallel out as the input? Sorry is this is a stupid question, I just don't want to damage it any further.
Just replace the plug. Its easy and you can get high quality ones cheap either locally or online say amazon. The cabinet will pop off but be careful w the screwdriver or whatever else you use to pry it off. I nicked my tolex when I did mine. It will take a slight effort due to the sticky seal stuff they put but it will pop off easily enough.
