The other day I lent a bandmate my oversized 4x12 to record some guitar with. He was playing pretty loud and at one point when he'd hit low palm mutes you could hear (and see!) the back of the cab rattling against the brace. I know that's what was happening, because it stopped when I pressed against the back panel. Should probably add that this cab has EVM-12Ls in the bottom two slots, and he was using an Ampeg VH150 which has some pretty crazy low end.
Anyhow, my first instinct is to just drill a couple of holes and screw the panel to the brace from the back, but I figured I'd check in with the BB in case there's a better solution.
