It is currently Mon Dec 17, 2018 1:17 am
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Sat Apr 23, 2016 10:16 am
I'm thinking about the breakthrough from Mesa over the last six years and wondering what could be folded back into the Mark V for the next update.
The basic premise here for me is: no new features or tones, just pulling in emerging or historical technology to make the basic Mark V better.
Here's my take on it:
1. Add in the Schumacher reverse engineered power transformer from the JP-2C. At face value this seems like it should be standard on all of the big daddy Mesa amps, even if it raises the retail price a bit.
2. Cab clone (duh)
3. Keep the multiwatt, variac power and rectification options, go back to supporting EL34s/6L6 mixes again. Class A with EL34s for Channel 2 vs full power on Channels 1 and 3 would be epic.
4. Like the older Marks, retain the ability to just use a quad of 6L6s on the outside instead.
5. JP-2C/Mark-V:x5-style channel master volumes
6. Corrected JP-2C/MVx5-style fx loop
7. Hell, while we're here: we've got midi on the JP-2C, it's be nice here as well.
[added]
8. Pull Gain and Pull Presence controls - these would have been HUGE for me with my Mark V.
9. Mid boost for channel 1
All of this raises the question for me: was there any one thing that prevented to iic+ mode on the Mark V from really being a IIC+ like the JP-2C is? Are they completely at odds with being able to make a Mark IV that offers the flexibility of the V without compromising the JP-2C tone for this hypothetical Mark VI's channel 3 iiC+ mode and channel 1's Clean mode?
Mark IIC+, III, V, Recto Reborn, TC-50
Sold: JP-2C, V25, Road King II, Tremoverb, Electra Dyne, ROV25
Twitter:mammothguitar
PostPosted: Sat Apr 23, 2016 10:25 am
in terms of things that could have impacted the Mark V's iiC+ mode tone compared to the real deal, here are some examples of what I meant:
- smaller power transformer
- additional tone option circuitry
- additional, different channels (JP-2C has 3 channels but two of them are the same channel type with differently tweaked values)
- Power amplifier architecture
- Additional wattage options
- Variac mode
- Different fx loop
Mesa has managed to nail the IIc+ again with the JP-2C. Obviously this is a great time to get all scientific method and figure out where the critical difference really came up. It could lead to authentic but fuller featured amps in the future.
PostPosted: Sun Apr 24, 2016 1:33 am
- Variac mode
- Different fx loop
Ahh, the Mark VI. I don't envy mesa with the task of creating something better than the V. :mrgreen: I did do some scientific experimenting today lol. I played the JP2Cs preamp through the Vs power amp. And the V pre through the JP2C power. The JP sounds good through the simulclass power. It doesn't sound as good, but it's a difference. The JP sounded less scooped through the V. Less low end. And just a hair stiffer on feel. It had an edge to it though, the simulclass didn't smooth the JP out. I don't think the JP can be made any smoother. More upper mids. Single notes did have more of that vocal thing going on. But probably because of the said upper mids. The V through the JP..... did not sound good. It took the boxy, honky, pointy nature of the V and made it worse. I was getting some sounds like the preset EQ dials were maxed out. A very pointy, sharp attack. Not pleasant at all, and not what I was expecting.
I ran from one amps fx send to the others return. Maybe the V just doesn't like sending its signal from that point, because the sounds coming out of the combo while it was hooked up to the JP were bad as well. But bad like I had no volume. So whatever that's worth.... :?: My take away is that the Vs power section sounded better than I thought it was going to. And the V doesn't like to send its signal out to be amplified at the fx loop.
I did notice that the JP seems to get to that sweet spot at a lower volume. The V, you have to get it loud before those tubes start to rip. Even after you get the V loud, it seems like it takes a few minutes at loud volumes to sound its best. Like it needs to warm up more. But with the JP, you get great tones right away at almost any volume. And they only get better the louder you go. Also. When you dime both amps. The Vs power section gets too loose. The power tubes break up too much and your tone gets flubby and messy. But the JP stays pretty tight. Or tighter I should say. The V stops getting louder once you go past noon on the master(loop bypassed). It just gets messier, the 6l6 break up gets more and more, and bloom it does. I think one would need special speakers for those tones. But the JP keeps getting louder all the way to about 2 or 3 o'clock on the master. And it's loud. After that it's just a power tube distortion control. I shot a .44 mag one time. Besides that, the JP is the loudest thing I've ever had control of.
PRS 408
Les Paul Custom 08
Edwards Alexi
Mark V
JP2C
PostPosted: Mon Apr 25, 2016 1:44 am
Ahhh, the mythical Mark VI....a couple of personal wishes:
1. Progressive Linkage. I never get tired of saying this. :lol: It's the one reason why I always considered the RK II the true flagship of Mesa amps, and it's also the missing link that could have turned the already great Mark V into a killer amp: ...6L6 cleans on channel 1, EL34 crunch on channel 2, 6L6+EL34 thump and grind on channel 3... :mrgreen:
2. While I get that one of the guiding principles in the design of Mark V was simplicity (as compared to its predecessors), I really miss the push-pull functionality of the earlier Marks. Surely adding (or, rather, restoring) some push-pull functionality to the pots wouldn't hurt? Or break the amp?
3. ....and, while we are at it, add (I mean restore) a separate Drive pot. To each channel.
4. Other than that, I wouldn't mind if they just made an improved version of the current Mark V. But the results might be even more interesting if they used the new JP-2C as the basis and worked it from there.
PostPosted: Tue May 17, 2016 3:23 pm
Wow, progressive linkage would instantly sell on a Mark VI. One of the reasons why I'm thinking about an RKII. Regarding push/pull, I'd like to see a push/pull pot on Ch.2 for the mid voicing. I use Mark I mode a lot with my neck humbucker, and being able to shift the mids just a touch would be great. The Mark I switch for normal/thick just doesn't cut it for me.
Mesa Boogie MKV
2x12 of some kind
ESP LTD EC-1000 w/ Seymour Duncans
Pedals by Fulltone, Voodoo Labs and EHX
PostPosted: Tue May 31, 2016 10:39 pm
I played with a Mark V combo for a bit at the Guitar Store here in Seattle. One thing that's been huge with the recent 25 watt amps and the JP-2C is the amount of switching that has moved to the FRONT of the amp. This would be a huge win with the next update to the Mark V.
I don't always want to have the foot pedal out and switching channels is a pain when you have to reach behind the amp to do it.
PostPosted: Wed Jun 01, 2016 9:25 am
I agree, plus get rid of the global output knob and fx loop hard bypass switch and basically just do what they have done with the JP2c with the loop.
PostPosted: Thu Jun 02, 2016 3:05 pm
+100
PostPosted: Wed Jun 08, 2016 4:33 am
Personally I don't think we'll see a Mark VI for many years, considering how long the Mark IV was in production and that Randall considers the V a compendium of Mark amps.
Funnily enough I met John Petrucci in February and mentioned how good it would be to have a Mark VB, same amp but with MIDI and built-in CabClone. He chuckled and said it would be cool.
So if Mesa end up doing that soon, I don't want to say it was my idea, but it was totally my idea. :mrgreen:
PostPosted: Thu Jul 14, 2016 1:32 pm
A lot of the new directions seem like smart moves: Midi support, etc.
But honestly the one thing I miss most is absolute insane tweakers dream that the older mark series were. The Mark V did away with the Pull Deep/Bass Shift/Treble Shift/Pull Bright/Harmonics or MidGain/etc shenanigans, and instead pared it down to it's simplest form. Now you get a toggle for the lead bright, and a toggle for combinations of those settings (you get small GEQ cap, pushed deep, etc in IIC+, large GEQ cap, pulled Deep, etc in the IV, and the negative feedback removal in Extreme.) Treble shift is locked, bass shift too, the first volume is stuck at 7.25, etc.
For the next one, I'd rather they go back to some of that insanity: Make the Gain a dual pot design with volume and lead drive. Add the pull deep, treble fat, etc to push pulls on the knobs, add one for the GEQ cap size rather than tieing it in these groups of modes. It would be less user friendly (The Mark V nailed that), but it would give back a lot of the flexibility that was lost.
Mark V
Studio Preamp
formerly: Quad Preamp, Rocket 44 112
PostPosted: Tue Jul 19, 2016 5:48 pm
Triple Recto
I would also like the integrated power tube capability 6L6 with EL34 and yet retain the quad of 6l6 or el34 for more flexibility.
What would thrill me is a 2x12 combo Mark VI. (or would it? love my RA100 combo regardless of how much it weighs) There are not many speakers available that can really take the 90W. I would opt for one or two Celestion Crème ALNICO 90W speakers. So far the best speaker I have used with the Mark V combo. Sure I could settle for a 2x12 cab but I prefer the open back combo, also easier to get to the tubes for replacement.
Take a few ideas from the JP2C (dual 5band EQ sounds like a good idea), Also add another Rectifier tube for the 90W mode. Oh yeah, add a bit of recto tone to it as a selectable feature or voice (Roadster CH1 tweed is far better than that of the Mark V). Love all of the features on the Mark V except for the edge mode on CH2, still have not figured out what I should use instrument wise with that voice as it just is terrible. It has been a while since I looked at the sample settings in the manual, perhaps I will revisit it and learns something.
If Simul-class will be used, reduce the bias on the center pair as they typically run too hot, would not hurt to boost the outter pair just a tad.
Design a better footswitch jack and cable. Whatever was done on the Roadster is much better as I have yet to have any issues with the footswitch, cable or connections. would a 9 pin DIN connector with oversized thumb screws would be a better? not sure on that.
PostPosted: Thu Jul 21, 2016 9:57 am
You can't reduce bias on the centre pair and have Simulclass. Simulclass is class A and class AB. The centre valves are class A and therefore have to be biased between 95-100%, as opposed to class AB which is typically 70%.
Mesa biased my MarkV at 95% on the middle pair and 75% on the outer pair, when using EL34's.
If it dropped below 95% it wouldn't be class A and therefore wouldn't be Simulclass. It'd be normal and very hot class AB with a transformer capable of handling both classes.
Not a fan of Simulclass myself. I like both A and AB. Just not mixed.
Peavey tried to steal someone I know's design of having a dial which balances an amp using both classes. So you can dial in how much class A or class A/B you want. I think that feature has some legs to it.
http://www.sheldonamps.com/truetone/tt3.html
some guitars and some amps
PostPosted: Fri Jul 22, 2016 6:36 am
Triple Recto
I beg to differ, The Mark IV is simul-class and the class A circuit bias is not as hot as the Mark V. The Mark V bias on the class A circuit runs hot enough to drive EL34 tubes without using the bias switch. I never burned up tubes in the Mark IV for the 15 years I owned it, where as with the Mark V, it has killed tubes in the class A circuit many times, between 1 to 2 weeks or up to 2 months. I soon realized I could no longer use Mesa branded 6L6 tubes in the Mark V, only tubes that did not fail were SED =c= 6L6GC. Since those are out of touch now as they are out of production and I do not feel like 3 times what they are worth, I decided to alter the main bias voltage by a fractional amount and now I can run the Mesa tubes without failure. Tubes are still within the bias range for Class A as the voltage divider network on the inner to outer pair was not affected. However, the EL34 bias has remained unchanged. When the amp is in the 10W mode, the bias circuit is not used as the tubes are operated in Cathode bias vs the grid bias.
PostPosted: Fri Jul 22, 2016 7:37 am
https://ia802508.us.archive.org/8/items ... 201975.pdf
Randal Smith's own writing on the subject, page 13.
http://www.mesaboogie.com/media/Files/M ... ooklet.pdf
http://www.aikenamps.com/index.php/the- ... on-class-a
Cathode bias has nothing to do with it. That just stipulates where the valve is biased. Rather than being restricted at the grid.
http://www.aikenamps.com/index.php/what-is-biasing
PostPosted: Sat Jul 23, 2016 12:32 pm
Triple Recto
I did not ask for adjustable bias, I prefer fixed bias. However, my Mark V was unusable as it red plates the recommended tubes every time they are installed. It was either get rid of the Mark V or fix it. The bias on the class A circuit does not have to be set that hot to sound good, in fact, the amp was brittle in all channels especially at full power. I can only relate to the Mark V I bought new in 2012, to me it was a disappointment due to issues. However when it is operating as intended, it sounds great. The Class A amp portion of the simul-class circuit of the Mark IV was better in some respects but did seem to be lower in power delivery than the Mark V. My amp has been fixed and I no longer have immediate tube failures as I did before. I can even enjoy the 45W mode with Mesa branded tubes. I can still get the plates seams to turn red when driving the amp hard, very much the same as with the Mark IV, since the amp was repaired and operating as intended, I have yet to red plate new tubes or old one's. Still bright but not as brittle as before. Adjustment of a millivolt on the main bias voltage is what was needed in my case. I could have easily run EL34 in the center pair with the bias switch on 6L6 for 45W and probably 90W but would not be suitable for the 10W mode.
I like the Mark V, just wish my first experiences with the amp were better than they were.
Users browsing this forum: No registered users and 9 guests
