It is currently Mon Feb 19, 2018 6:54 am
 Post subject: Tremoverb problem
PostPosted: Wed Feb 10, 2016 7:41 am
I've got a bit of an issue with the mid control on the orange channel of my tremoverb combo. It is scratchy around the 12 o clock position so I can't set it at this level (the 'scratchiness' at the 12 o clock setting means that the mid control skips immediately from too low to too high...if that makes sense!!)
Any ideas on how I can fix this? Perhaps I need to clean the pot? If so any advice on this would be much appreciated! Thanks!
 Post subject: Re: Tremoverb problem
PostPosted: Sun Feb 14, 2016 1:54 am
Clean it with Deoxit Gold.
Use it to clean all of your pots, jacks, switches, tube pins, tube sockets, etc about once a year. Spray it on the pot and rotate from off to full at least ten times. Allow to completely dry and do not spray to much. A little is all that is needed. It can be found sold in many places...
http://www.musiciansfriend.com/pro-audi ... tads-plaid^157459348602-sku^429168000000000@ADL4MF-adType^PLA-device^m-adid^93130364907
Users browsing this forum: Google Adsense [Bot], JamminJoe and 3 guests
