Rectifried
- Joined
- Jun 22, 2014
- Messages
- 55
- Reaction score
- 0
This is probably a better question for Mesa support but hoping someone here can help me figure out what is going on. So I have both a Mark V:25 and a Mini Rectifier, and want to use both. I have 2 separate cabs so that is not an issue. I have a G Major, and a midi foot controller. I purchased a Voodoo Labs Hex looper and a Radial ABY. So the idea is feed both amps from the ABY. Route the fx send from each amp to a separate loop return on the Hex, say loop 2 and loop 3. The idea is only one return can be active at a time. Then feed the output of the hex to the G Major, and the outs of the G Major back to each amps fx return. In theory that should work. I think.
But what is happening is it seems the fx loops work at different levels between the 2 amps. I can barely go above 8 o'clock on the master on channel 2 of the V:25 without hitting the return of the mini rectifier too hard, while i have to crank up the master of the mini rec channel 2 to about 10 oclock to get a decently audible signal in the return of the V:25. I have swapped cables and outputs and such, none of that is the issue. To simplify during troubleshooting, I hooked up just the V:25 to the G Major, got it working fine, then added the mini rectifier simply as a power amp from the other output of the G Major (not using the mini rectifier preamp at all. Same basic issue, can't go above 8 oclock without hitting the mini rectifier return too hard.
So it really seems like the loops just run at vastly different levels, which would kill my plan.
However, I noticed one other thing on the mini rectifier by itself. There seems to be some bleed of the preamp signal outside of the fx loop. In other words when using the fx loop, I can mute all output from the fx unit, but still hear a fairly strong but thin signal coming thru the power amp. I even unplugged the return and the signal bleed was still there. SO that does not seem normal. Has anybody else run into this? I'm almost hoping there is something wrong with my mini rectifier so I can get it fixed and hoepfully have this setup work.
Thanks for reading all of this and for any who have input.
