1983gibsonexplorer
- Joined
- Jul 23, 2015
- Messages
- 1
- Reaction score
- 0
Hope it's alright to ask this question here. I have a single rec. rectoverb 50 combo. The jacks on the back are 8 ohm and then two 4 ohm. It says under the 4 ohm jacks use with 8 ohm speakers. I have a 4x12 stereo cab and when switched to stereo it's 8 ohms per side. So can I run two cables from the 4s and run this in stereo safely and can I leave the combo speaker plugged in with that config? is this a good setup ? When set normal the cab is either 16 or 4 ohm. I tried the 4 ohm option on the cab plugged into one of the 4 ohm jacks on the cab with all 4 speakers and the combo speaker unplugged sounded very thin. Didn't try the 16 ohm plugged into the 8 ohm jack yet to late here. Just trying to find the best option using this along with obviously being safe about it. Thanks
