etepbbb said:Just do a p/n cross reference on Google, seems to be a few alternatives available. I would verify the fit and function through the datasheets, though.
thunda1216 said:have you tried contacting Mesa? They may have one in stock.
thunda1216 said:on some of those part numbers, the "N" indicates it is an OEM spec part. Mesa may be able to give you an alternate part number for replacement if they don't have any in stock. good luck with your search.
Authorized Boogie said:thunda1216 said:on some of those part numbers, the "N" indicates it is an OEM spec part. Mesa may be able to give you an alternate part number for replacement if they don't have any in stock. good luck with your search.
I returned your call, Russ - give us a ring when you can, we have them available!
Old BF Shred said:Are you certain the relay is bad?
A poor solder joint could also cause these symptoms.
Try gently rocking the relay back and forth as opposed to tapping it. If it acts up, try touching up the solder on the pins and look for cracks in PCB/solder joints in the vicinity.
Even if this makes no difference, poor solder joints could still be the cause. They are notorious for intermittent problems.
Good luck!
RussB said:Old BF Shred said:Are you certain the relay is bad?
Good luck!
I don't know for sure, but I'm not going "in" without a new relay available. I can't see a way to solder/unsolder the relay without removing all the pots from the face and lifting the board up.
I did order 2 relays from Mesa today
Authorized Boogie said:RussB said:Russ,
Don't unsolder all the pots!!!!!!
You want lift the board from the rear. Squeeze and push the standoffs through the board - then lift up the rear edge of the board towards the pots. If the wires to the power tube board aren't letting you lift enough - remove the 4 screws on the power tube board. De-solder as little as possible!! Then, locate the old component and wick or solder suck out the old solder - the component should fall out - and replace! Very simple job on a Solo 50. Hope that helps. Thanks!
Authorized Boogie said:Ah. I see your amp has been modded.
I ran this past our lead tech. He asked if you are SURE its the relay, and not something controlling the relay? Many times he's had to fix homebrew repairs when the person THOUGHT it was the relay and its really not. They rarely fail.
Best of luck!
Best of luck!
Enter your email address to join:
