Nomad 100 head: the EQ cuts only, no boost
balokker
Nomad 100 head: the EQ will cut frequencies fine, but there is no boost when you push a slider past the center line. When the EQ switch is engaged, there is a volume drop until the faders are pushed all the way up, then you're back to unity gain. Anyone else ever have this problem? Q1, Q2, Q3 or Q4?
