Tremo-verb combo trade for dual rec!
TheArriaga88
Hello all! im in desperate need of some advice ive come across the opportunity to obtain a 1994/95? tremoverb 2x12 combo, the guy wants to trade it for my 2005 dual rec half stack. :|
im itchin bad to pull the trigger on this one! where i live you dont come across these trems too often, and i know that down the road another dual rec halfstack could be had its just a matter of money. i need some opionions!!
Lead me to the light gentlemen!
I wouldn't do it without cash on top of the combo. IMO your half-stack has more trade value than a 2X12 combo.
What is it about the Dual Recto that you don't like that makes you want to trade? While many feel that the older TOV's sound a little different, it's still a Rectifier non-the-less.
Dom
Personally, I'd go for it.
However...
Yes, the TOV and your current Dual sound different, even through the same cab. Try to A/B them as thoroughly as possible - through the same cab, and the internal 2x12 vs the 4x12 as well - to find out which sounds better to your ears.
There are also other aspects to consider. The TOV 2x12 is insanely heavy. It is a roadie's nightmare. If you are planning to gig with it, try lifting it first and then decide how often you want to do that.
