Laskyman
Is there any harm in running channel 2 and 3 in 10 watts pretty much all the time?
bandit2013 said:...You may also want to swap tubes after a while (say a few months or so), exchange the two outer tubes with each other, and the same with the inner tubes....
10W mode is single ended Class-A (sort of) and uses one inner & one outer powertube in parallel (explained in the manual). This is why Mesa does not recommend running EL34's in the Class-A spots with 6L6's in the other positions of the MKV, but it's fine to do in the MKIV (no 10W mode).shimmilou said:bandit2013 said:...You may also want to swap tubes after a while (say a few months or so), exchange the two outer tubes with each other, and the same with the inner tubes....
I agree about swapping the tubes to let them wear evenly, but don't you mean put the two inner tubes in the two outer tube positions and vice-versa?
domct203 said:shimmilou said:bandit2013 said:...You may also want to swap tubes after a while (say a few months or so), exchange the two outer tubes with each other, and the same with the inner tubes....
Dom
Enter your email address to join:
