shimmilou said:If you plugged your preamp directly into the Mark V return, with guitar plugged into the preamp, you have bypassed the Mark V preamp section which includes the EQ.
Yup. I wanted to do the same thing as you. The EQ on the V is not active when you plug a preamp into the effects return jack.Does the EQ section of Mk V part of the power section? I tried to use an external preamp and the EQ does not work?
shimmilou said:The schematics that I have show the Mark I and Mark II have the EQ before the Power amp in, not part of the power section. It seems kind of odd that any amp would have the EQ as part of the power section. :?
Enter your email address to join:
