Still loving my Nomad ...
bgh
Post by bgh » Tue May 07, 2013 6:56 am
Most of the playing that I do nowadays is for our group at church. We play during the service. And, some of us meet to form a separate group through which we present originals that we have written.
For a while, I was lugging my Mark IV back and forth, and using it to play through. I love what that amp can do and what I can get out of it. Fantastic amp! The only problem was that it was heavy. My son would usually carry it for me, but I had to carry it a few times when he was not there. With my age and arthritis, it was more than a challenge.
Because of that, I chose to take my modeling amp (a Peavey Vypyr tube amp) to church and leave it there. It worked out pretty well. The amp got close on a lot of the tone I wanted. Plus, I did not feel too bad leaving it there.
Then I decided to carry my Nomad 45 1x12 to church once and try it. Wow. What a surprise. I was able to fit in and be easily be heard above the mix. I dialed in three different tones on the three channels, and simply switched as needed. The cleans were very nice! They produced a real cool echo. I used channel two for a crunch rhythm. It rode the mix a lot better than did my Peavey. Channel 3 has a great lead tone. I am able to get very expressive playing my SG through it. (Strangely enough, my LP doesn't sound as good through the Nomad as does my SG. Weird, huh?)
The Nomad is considerably lighter than the Mark IV. Plus, it fits rather nicely in our trunk.
You don't see a lot of threads about Nomads. I must have lucked out and gotten a good one. All of the pots work. The reverb is nice and can be heard on all three channels. (Those were the two most common issues I hear being reported concerning the Nomads).
Anywho, thought you might be interested ...
PS: Anybody else care to share about their Nomad use?
Lefty guitars: Gibson SG standard (1977) • Gibson LP custom (1979)
Amps and such: Mesa Boogie Mark IV-B • Mesa Nomad 45 • Peavey Vypyr Tube-60 • Effectrode Blackbird • Kingsley Jester • AMT SS-11a • Zoom G5
NomadExpress
Re: Still loving my Nomad ...
Post by NomadExpress » Sat May 11, 2013 5:14 pm
I love my Nomad 55. I did mod it and added the extreme switch.
Do you use it in "extreme mode?"
bgh
Post by bgh » Sat May 11, 2013 11:20 pm
Sometimes. The clean channel (both normal mode and pushed mode) take on a whole new dimension in extreme mode. Not just in volume either. It seems like a get a whole new set of dynamics. I use normal mode, though, for softer cleans.
For channels 2 and 3, I still have not completely made up my mind as to which mode I like best.
PS: Do you get a slight hum when you switch to extreme mode?
NomadExpress
Post by NomadExpress » Sun May 12, 2013 1:50 pm
Yes, the hum does increase in extreme mode.
bgh
Post by bgh » Sun May 12, 2013 2:17 pm
Mine too.
How do you differentiate between your use of channels 2 and 3.
I use 2 for my lead work, and 3 (with the mids pushed) for my crunch rhythm work. I love the bass response I can get on leads on channel 2.
Tommy_G
Post by Tommy_G » Tue May 14, 2013 12:05 am
I don't use my Nomad much since I discovered how great my heartbreaker sounds with EL34's, but....one day I will trade my Nomad 100 (overkill) for a Nomad 55, and mod it. Its got a lot of potential and I'm pretty sure that with some small circuit tweaks I could get it to where I'd like it more than the HB.
What speakers and cabinet style are you guys using with your Nomad?
lespaulguy32
Post by lespaulguy32 » Tue May 14, 2013 12:16 am
Nomads are some real kickass amps, I tell ya hwat...
Guitars:
- PRS Hollowbody II
- PRS Custom 24 (2)
- Chapman ML-1
- Gibson Les Paul Robot
Amps:
- Road King II Combo (2012)
- Tremoverb Combo (1998)
- Triple Rec 3 channel (2004)
- Recto 4x12
Garyh153
Post by Garyh153 » Wed May 15, 2013 4:35 pm
Love my Nomad 55, but the handle is starting to wear badly. Anybody know where I can get a replacement? Cheers.
bgh
Post by bgh » Fri May 17, 2013 2:50 pm
Tommy_G wrote:What speakers and cabinet style are you guys using with your Nomad?
I have the Nomad 45 1x12 cabinet and the stock Black Shadow MC-90 speaker. Some people have indicated that they do not like it, but, it sounds pretty good to me. My SG sounds a lot better through it than my LP (not that the LP doesn't sound good!).
I was playing some at lunch earlier. I love how the gain on channels 2 and 3 is such that you can really control the note decay with your finger. I believe it is actually a little more sensitive than my Mark IV! Anybody else notice the control that the Nomad gives you on note decay?
I have been noodling with channel 3 and have come up with a setting that sound like my old Marshall MK-II Lead amp used to sound like. Now, this is going back a number of years. However, the Nomad is giving me that screech and chunk melded together. That was one of the things I liked about the tone that I got out of my old Marshall.
bgh
Post by bgh » Tue May 21, 2013 10:10 am
One thing has come up that I do need to ask about. Last night, after playing for over an hour, I found that the gain and presence controls for channel 2 were harder to turn. It was like the pot was swollen and was hard to move. They did loosen up after I powered off and the amp cooled down.
I am worried that I have done something to my amp (by trying to force them to turn).
Has anyone else run into this? If you have, what did you do (if anything)?
I am considering taking one of our portable house fans an pointing it toward the back of the amp to try to move the air around. Has anyone done this?
Should I look at adding an old CPU fan to my amp?
jaynthia
Post by jaynthia » Sat Jun 08, 2013 2:22 am
That's strange, never came across. But I don't think the working temperature will affect the pots.
It's pretty simple mechanical structure in the pots and nothing in it will swell up by high temperature or someway else.
BTW, what's the hi-gain lead and rhythm sound like, compared to Mark series, I'm a Mark user and just searching for something new. Thx.
Mesa Boogie
Mark V head Custom White
Mark IV-B Long Head Custom Snake Skin
Lonestar Classic Custom Short Head Coal Black
Stiletto Deuce II Tan Weave
Triaxis
Quad
Formula
2:100
2:90
2*12 Recto Wine Red&Wicker
2*12 3/4 Back Tan Weave/V30s
1*12 3/4 Back
bgh
Post by bgh » Sat Jun 08, 2013 8:22 am
jaynthia wrote:BTW, what's the hi-gain lead and rhythm sound like, compared to Mark series, I'm a Mark user and just searching for something new. Thx.
The crunch and high-gain from the Nomad are good, but not as good as my Mark IV. They are different. The lead tones from channel 3 of the Mark IV are great. The lead tone's from the Nomad channel 2 are a little more raw. They are not as creamy as the Mark's leads. The Nomad has more of what I would call a "brown" sound. I find it to be a nice complement to the Mark's sound.
Channel 3 on the Nomad can get very high gain, but it can get away from you easily and turn into rubbish. It's lead tone does cut through a mix nicely.
Both channels 2 and 3 can give some nice crunchy rhythms. Channel 2 for vintage, channel 3 for modern.
By the way. your quote describes exactly why I got my Nomad. I had a Mark and wanted something close, but a little different. For me, the Nomad filled that void.
rumpel
Post by rumpel » Mon Dec 23, 2013 6:34 pm
Hi!
I also love to play may Nomad 45 Head. "Extreme" mode sounds pretty fine, but I also have some humming. The humming is so load that it really disturbs me. Has anyone of you an idea, what I could do to reduce humming in "Extreme" mode?
bgh
Post by bgh » Thu Dec 26, 2013 8:43 am
Mine does it too in extreme mode. Not sure what can be done about it. Luckily, the amp is loud enough that I don't hear the hum when I play. But, it is a distraction when I am not playing. I have taken to hitting the standby switch in between songs (when in extreme mode).
rumpel
Post by rumpel » Mon Dec 30, 2013 7:14 pm
Hi bgh!
Thanks for the hint. I wrote an email to Mesa Boogie, but I'm also afraid that there is not much that can be done, except switching into standby between the songs. I will play in extreme mode nevertheless. The second chanel sounds so dynamic and bright in extreme mode, makes the amp a bit more british in my opinion
