Can I use JJ EL84 tubes on my Mesa TA-15?
imc2111
I need to replace my power tubes, the whole bias thing has me confused. Can I just put some standard JJ tubes on this amp?
Yes, but be sure to tell the seller that they must be rated to run in your Mesa so they bias up correctly.
BTW- non-Mesa tubes void your warranty. If the amp sustains damage from a tube failure the repair tech may ask you for the bad tube as proof that Mesa tubes were in the amp at the time the damage occured.
Food-for-thought.
Dom
