GEAR
My Heartbreaker is setup with stock Mesa 430 6L6's, running 60W (half power mode), into a Lonestar 1x12 Extension Cab with 8 ohms on the speaker, 4 ohms on the amp output (which is recommended when you go to the halfpower mode). My guitars include a 1996 Anniversary Yamaha SG (set neck with the HB SG3000 pickups), a Guild Liberator Elite with Active Bartolinis HSS) and a couple of G&L's which I haven't got around to using with this yet.
This review is based on using the Heartbreaker's Lust (Marshall-y) Channel, both Lo and Hi gain with the Reignmaker FDM Speaker. Incidently, I don't have a lot of experience comparing speakers with my gear. All I really can compare against is tone-memory from using the MC90 in the same Lonestar 1x12 cabinet. I've tried to relate my observations back to the speaker curves where possible.
MOTIVATION
I couldn't resist buying on spec an Eminence Reignmaker, with the FDM (attenuation) feature, because I figured it would be a way to get some power tubes cooking on my heartbreaker at bedroom practice levels. In a normal situation with high sensitivity speakers, the Heartbreaker master and final volumes have to be almost off to practice, which is a tone suck in itself.
FDM ATTENUATION
On the main feature that attracted me to the Reignmaker - the FDM feature gets it done pretty well. I can turn my amp to nearly gig levels and the FDM on the highest level of attenuation (lowest sensitivity), and the volume is quite acceptable. However, as the frequency curves illustrate quite well, most all of the attenuation increasingly happens above 100 Hz (eg..the bass isn't attenuated much at all), and so at high levels of attenuation, the tone becomes relatively boomy, and the bass control on the amp needs set really really low to compensate, and the tonal balance doesn't quite hang in there all the way through the range. I think splitting the difference about 50/50 is a better compromise than hi amp, hi attenuation - so maybe count on about 4-5 dB attenuation.
LINEAGE
The Eminence rep indicated that the Reignmaker is voiced most closely to a Private Jack, and the internet rumours are that the Private Jack are the Eminence take on the Greenback. I've always liked the sound samples i've heard of greenbacks. One usually thinks about a 'woody tone'. One of my guitars is about the 'woodiest sounding' electric guitar ever made, a Yamaha SG1996 Anniversary edition. The clean tone with this guitar and speaker is awesome.
PRESENCE/HIGHS
One of the complaints I have read from people comparing Eminence to Celestion is that in recorded samples, Eminence doesn't seem to have the extended highs and 'presence' of the Celestions. I think the Reignmaker will be an exception to that general complaint - its frequency range goes up into the 6k+ range and you can hear it.
Given the inherent darkness that *is* the Heartbreaker Lust channel - I have to turn the presence down to less than 25%-50% to mitigate the highs of this speaker whereas run 100% presence with the MC90 at bedroom levels (and a 6dB presence boost would be about right on top of that...)
The highs are 'crunchy' sounding highs, and not smooth highs, and having too much of them with a high gain tone makes the speaker sound like its going through some sort of fixed frequency presence notch boost, rather than smoothly following the harmonics of the note being played. You can hear that characteristic on Youtube samples dealing with Greenbacks, too. Some may like that signature sound. I'm coming from a very clean and uncolored speaker, so that signature is a little unusual to me.
Adjusting the presence control down helps tame that tendency on distorted tones. On clean voicings, however, those upper crunches add an element of expressiveness that I really like.
Fret buzz is more noticeable with this speaker than with the MC90 (to be expected from a brighter speakers). Guess I'll have to lay it out for a guitar tech
Since I don't have a lot of experience with new speakers, I can only guess that the better part of breaking in a speaker is softening up and smoothing out the response to the high frequencies - the cone is probably a little too rigid new out of the box.
MIDS
The frequency curves show another characteristic - that the relative levels of the 200-500 Hz range are suppressed relative to the 100 Hz and especially the 700-1000 Hz range.
What seems to happen with this characteristic is that the upper neck lead tones smoke pretty nicely. However, this same characteristic has a tendency to create a bit of a thinned out tone (not enough 'body') in the crunch settings I've been using on the Hi Gain setting of the Lust Channel for rhythm stuff. In comparison, I find there is perhaps too much 'body' to the MC90 - and not enough balance on the upper harmonics with that speaker. The Reignmaker probably goes too far the other way for me, for distorted tones. Yet, when switching to the cleaner low gain tone on the lust channel, it sounds balanced, expressive and silky.
I GREATLY prefer the clean rhythms to the crunch rhythms with the Reignmaker. I've gone back and listened to some youtubes of crunched distortion tones through a Greenback, and find that crunchy high's 'signature' to be similar to what I'm hearing in the Reignmaker.
ARTICULATION
The speaker curve shows a big dropout of frequences between 1200 and 1800Hz (more than most speakers), which is where some pretty harsh sounding harmonics generally come from, except that (if I remember correctly), where some of the 'pick attack' comes from, particularly with distorted tones. The string attack is subdued accordingly, with just enough there to hear it, but not enough to make a case that the tone sounds super-articulate. In a gig situation I normally run an eq in the effects loop so I can probably dial back in some of these frequencies without a lot of compromise since they are not very important except as transients. The clean tone attack transient sounds perfect, as that little bit of high freq crunch enhances the attack in an expressive/percussive manner.
SUMMARY
So, for Marshally tones at bedroom volumes:
1) this speaker excels at beautiful cleans; silky meaty, and...yes woody.
2) driven lead tones on the upper neck are smoky
3) don't care for the voicing of thick crunchy rhythm tones
4) the attenuation meets expectations
FINAL COMMENT
To get the die-for clean tones, the Marshall style tonestack needs a considerable reduction of the treble setting. I've found about T=9:30; M=1:30; B=9:00 to work very nicely. By comparison, the MC90 had the treble and bass at about noon, but didn't sound near this good.
I'm pumped about the clean tones I'm getting with this speaker. Right now, I can't think of a way they could be improved. The Reignmaker attenuation gives that ability to push the power amp along a bit more where there is an enjoining of power amp compression and distortion alongside the speaker breakup and therin reside excellent dynamics, expressiveness and sustain; lots of good solid tone that makes you just want to play clean and enjoy a silky natural sounding tone.
Although I bought this speaker to crunch with, I'm actually not thrilled with how it handles preamp-driven crunch tones, but it stands to reason that no one speaker does it all. Hell, I'll settle for perfect sounding 'on-the-edge' clean tones instead! This speaker opens up that whole avenue of tone with my rig.
Greenbacks were the speaker of choice for a lot of hard rock musicians using marshalls, and one would think that classic marshall tone has as much to do with greenbacks as the marshall amp itself. This said, it is noted that the Greenback is heavily influenced by the amount of volume put to it, and I have no idea at this point how that will play out with the Reignmaker - but will hopefully have a chance to play it loud with my band at a jam or gig in the coming few weeks.
The one outstanding question I have is whether or not this kind of attenuation is absolutely necessary. Speaker manufacturers have to catch on that we are in a new tonal era where people are moving to smaller power amps as a result of looking for more power amp tonality. Coliseum-sized amps for the bedroom are out. A 50W amp running a 94dB speaker is like a 12.5W amp running a 100dB speaker.
The Manufacturers need to design their speakers around a 95 dB sensitivity rating, and not always shoot for the mind numbing pain of 100 dB rated speakers. That way, 6L6 guys can enjoy the signature of their power amps in the privacy of their own home. Until they do, the Reignmaker has its place.
MOTIVATION
FDM ATTENUATION
LINEAGE
PRESENCE/HIGHS
MIDS
ARTICULATION
SUMMARY
FINAL COMMENT
