I own a 2009 3-channel Dual Rectifier with a 4x12 recto cab. I've been endlessly searching for a tone similar to Alter Bridge, Limp Bizkit, 12 Stones kind of tone, in other words, tighter, but still american sounding. I've tried pretty much everything:
1) Tubescreamer TS-7: tightened up my higher gain channels, but gets really annoying having to turn it off when going back to the clean channel, it still has a drive, even with it all the way down.
2) Boss GE-7 equalizer: as a clean boost. If I boosted the 800-1200Hz sliders, the high gain channel sounds awesome, but screws up my clean tone, if I'm to leave it on, as I like a mid-scooped clean tone.
3) EL34s: tightens up a bit, but I kinda prefer 6L6s for the clean channel.
So I've been doing some research and came across Voodoo amps, they offer mods for the recto. From what I've heard in their site, it's seems pretty awesome. But I also came across reviews of the Mark V, and fallen pretty much in love with it. And finally, the Road King, which you can select which tubes you want for each channel.
Other than that tone I'm looking for, I need some versatility, an amp capable of chimey clean sounds, and tight low and high gain sounds. I play mostly post-grunge, but also ska-punk, jazz and metalcore, so it needs to cover these styles as best as it can, other than getting "that" tone.
Should I:
a) Have my Dual Recto modded at Voodoo?
b) Ditch my DR for a Road King?
c) Ditch my DR for a Mark V?
Should I:
