What tubes are in your amp and why?
StrykeBack
Post by StrykeBack » Thu Apr 07, 2005 5:52 pm
I've got a rectoverb series 2 head that I'm going to be retubing and wanted to get a feel for what you guys were using in whichever amp you have. Any why you decided to go that route.
So if you could say what amp your using and what tubes you got and perhaps what didn't work that would be awesome guys.
screamingdaisy
Post by screamingdaisy » Thu Apr 07, 2005 5:55 pm
Svetlana 6L6 - I like them for their sound....they keep the stock Sovtec flavor, but just taste better.
Dale B.
Post by Dale B. » Thu Apr 07, 2005 9:20 pm
Let's see here:
Mesa Mark IV - Well, I have some older SED 6L6GC's, when they were still Svetlana, in the power section and some RCA 12ax7's in every slot except the Phase Inverter, which has a JAN GE 12ax7wa in it's slot. Why are they in there? This combination can sound smooth or aggressive depending on how I dial the amp in. The overall clarity is top knotch mated with that sweet Boogie preamp saturation. I'm scared to even turn the dials on the amp. :)
Triple Recto - Ruby EL34B-STR's in the power section, RFT Ecc83's in V1 and V2, EH 12ax7 in V3 and Ruby 9th Gen Chinese in the Loop and Phase Inverter. The EL34B-STR's give the amp more depth and smoothness, but the RFT's in the first 2 slots aid tremendously to the overall tone of the amp as well. It's kind of like pouring chocolate syrup over chocolate brownie ice cream. Those tubes working together thicken things up a great deal, but it's real smooth and sweet. The EH is at the end of the cascading gain stack and is also driving the tone controls. The Chinese preamp tubes work really well in the Phase Inverter. I don't use the Loop because I don't run effects.
I've got other amps, but they're not Mesas. :)
Dale
NoGlassNoClass
Post by NoGlassNoClass » Thu Apr 07, 2005 11:07 pm
Triple Rec
JJ ECC83 Hi Gains in V1,2,3, a regular ECC83 in V4, and a balanced one in V5. Why? because I wanted to try something different, heard the rave reviews and gave 'em a shot. No regrets. They sound killer...much better than the stockers. When the long-plate 803's are available I will try one in V1 just to see what it does.
Power section: SED 6L6's (Mesa STR454). Not much different than the STR430's that came in the amp, a bit tighter and maybe a hair louder too (!) Why? Was going to try the JJ's here too, but I had a tube go redplate on me during rehearsal, and my local music store had GT (ewww), and Mesa 430's and 454's.
Rectifiers: JJ GZ34 (5AR4). Why? Punchy as the diodes, no volume loss, and still retains just a little bit of the rectifier "sag" that makes soloing sound sweet.
Yes, I bought into Bob's hype...and happy I did! I'm not really one to change tubes just for the hell of it (not too often anyway). Routine maintenance, or if I get some that just plain sound bad. I am very happy with this amp now, and will probably retube with the same thing next time.
jbird
Post by jbird » Fri Apr 08, 2005 2:37 am
I run the stock Mesa branded tubes (EL34's) in my two channel Dual Rec. The local dealer is two minutes away, it's just convenient! I'm satisfied with my tone, I have'nt justified the need for tonal improvement via tubes. Instead, I just buy another PRS guitar, or at least a new set of strings. :lol:
cvansickle
Post by cvansickle » Fri Apr 08, 2005 6:03 am
My Nomad 100 212 has Electro-Harmonix 6L6EH tubes in it. I first started using those in my old DC-5. Right now the pre-amp tubes are stock, but when the time comes to replace them I like the 12AX7EH tubes.
My NOS Blue Angel is stock.
Death Or Glory - Who Dares Wins!
CudBucket
Post by CudBucket » Fri Apr 08, 2005 8:48 am
Currently:
V1 = GT Mullard Reissue
V2 = Electro Harmonix
V3 = Shuguang 9th gen.
V4 = Shuguang 9th gen.
V5 = JJ ECC83
P1, P2, P3, P4 = SED Winged C 6L6GC
Why?
Because I wasn't happy with the 5 JJ preamp and 4 JJ Power Amp tubes that were in there. The current config. sounds smoother and warmer to me. I still have the JJs becaue I expect to put them back in and see if I've changed my mind about them.
I think my favorites though were the stock Mesa tubes which I don't have anymore.
Dave
StrykeBack
Post by StrykeBack » Sat Apr 09, 2005 4:00 am
Wow, you really think that? I bought my rectoverb used and though the guy said he barely played it, I know from experience that my last amp sounded so much better after a fresh set of tubes and almost consider it a waste for the first 3 months I had it with old tubes. I think I will always do that with a new amp. Just to start fresh, new tubes.
Currently:
V5 = JJ ECC83
That configuration looks very similar to what Doug was recommending to me except maybe a JJ high gain in the electro harmonix spot. I think I will try teh JJ 803 in V1 as well.
CudBucket
Post by CudBucket » Sat Apr 09, 2005 8:17 am
I got the first four tubes from Doug. ;)
StrykeBack
Post by StrykeBack » Sat Apr 09, 2005 10:13 am
Did you try other preamp tube configurations before you ended up with that? I'd like to skip the hastle and get to what works best so I can focus on playing the guitar :twisted:
redmax61
Post by redmax61 » Sun Apr 10, 2005 1:28 pm
I run the stock preamp tubes. But in the output section I'm running a pair of EH EL-34's and a pair of THD Yellowjackets.
I did a lot of experimenting with tube configurations, but this one just happens to be the most pleasing. It really tightened up the bottom end and gave the top end a more vintagy vibe.
Robin F. - Master of my own Density
PRS guitars
Mesa Dual Rectifier
F/A custom built heads
Marshall 4x12 cabs
no soul
Post by no soul » Wed Apr 13, 2005 2:39 am
stock tubes in everything!
why? Because Im too cheap to retube em, and last time needed a re-tube I was given some Mesa STR430s, so in they went.
I do have have a pair of old american 6l6s (GE I think). Which sound nice and I toss in here and there for sh!t and giggles.
handsome east bay ninja
StrykeBack
Post by StrykeBack » Sat Apr 16, 2005 3:55 am
OK guys, my tubes arrived today and I'm wondering what each V of the preamp does what? I know v1 is supposed to be your drive channel but?
I've got 2 of the new telefunken copy JJ 803S ( 1 of them balanced)
1 high gain JJ 83S (balanced)
and 2 Shuguang C 9th generations (1 balanced)
Along with the 2 SED 6l6s.
Since I've got a few balanced tubes I've got options to try on the PI but the layout I was thinking in my head was:
V1=803S
v2=803S
v3= shuguang
v4=shuguang
V5=JJ 83S high gain.
Does that look about right or should I mix it up other places?
NoGlassNoClass
Post by NoGlassNoClass » Sat Apr 16, 2005 12:39 pm
You might have trouble with microphonics using the 803 in V2. Long-plate preamp tubes are more prone to micrphony, and the 803 has VERY long plates. Try the ECC83S in V2 and put the balanced chinese in V5.
According to Bob at eurotubes, the 803's are good in all slots for vintage amps, but in high gain amps you should only use it in V1 because of the microphonics issue.
I should have a couple of ECC803's sometime this week, one for V1 in my Triple, and one to try in a Marshall. Will post my findings.
StrykeBack
Post by StrykeBack » Sat Apr 16, 2005 7:22 pm
then where should I put the other 803? :( 5 preamp tubes and 5 preamp slots and 2 of them are 803s...damn, is the v2 the first gain stage of the overdrive, or lead channel?
