Hi again If you read my thread over here I explain that last night I finally got around to tryin the POD XTL in my loop return http://www.grailtone.com/forum/viewtopic.php?t=399
Today I played with it some more and noticed that switching between channels totally changes the sound though the channel controls on the front of the amp do nothing.
I noticed because by default my Triple seems to start in the 2nd channel where as last night I had it on the clean channel from playing through the front first. My clean channel is much lower in volume than my 2nd and 3rd channels so it startled me at the same time haha.
How is this ? I mean it is supposed to bypass the pre amp stage so how would switching the channels make a difference but yet the knobs do nothing still. can anyone here explain ? Does this mean the Pre Amp tubes are used then as well ? Upon reading in the manual it just states that the channel 2 and 3 select switches will be enabled and nothing more.
