nomad mods
Optical
Re: nomad mods
Post by Optical » Fri Oct 26, 2018 9:43 pm
Thanks to the people who have posted in this thread. I have a Nomad 45 which I have spent some time modding.
I have done the mud mods - PI plate caps removed and the FX loop cap swapped to 47pF. Preamp low pass output cap removed
Crunch and Lead reverb return resistors are paralleled with 100k resistors to get it loud enough for my taste. I experimented with the reverb send stage in case those diodes were clipping but it didnt make a difference, didnt explore further.
Now - there are some good mods to be made to channel 3 to make it significantly less mid-scooped and give it less bees.
Short the 1k resistor in series with the V3b 0.47u cathode cap
The 680k treble peaker resistor sounds much better at smaller values,I settled at ~390k (680k and 1M in parallel) for a good modern sound. 470k sounded good too.
This was combined with reducing the value of the gain pot - i used a 220k resistor across the existing wiper and ground. The wiper resistor tightens up the lead channel a bit, reducing the treble peaker resistor brings out the mids.
Here is what I ended up with. The lead channel sounds very close to the dual rec now. Crunch channel isnt substantially affected. I call it the Bees mod :p
sentari
Re: nomad mods
Post by sentari » Sat Jan 05, 2019 4:19 pm
It seems the pictures that Normad100 posted have been gone for some time. Can someone post them or point to/give some specific instructions to the mud and reverb mods?
balokker
Re: nomad mods
Post by balokker » Mon Jan 21, 2019 6:05 pm
Thanks for the mod list Optical.
I found that treble peaker to be a critical voicing factor as well. I went with 235k (two 470s in parallel) and 681pf.
What did you get from changing that 1M to 220k on V4a? Looks like it will boost the signal working with the other 1M on the grid.
Optical
Re: nomad mods
Post by Optical » Thu Oct 31, 2019 10:19 pm
The 220k raises the rc filter frequency made with the coupling cap.
Essentially a tighter bottom end
