It is currently Mon Jan 21, 2019 9:18 am
Post new topic Reply to topic  [ 167 posts ]  Go to page 1, 2, 3, 4, 5 ... 12  Next
 Post subject: nomad mods
PostPosted: Wed May 27, 2009 3:28 pm
What if i could say that removing 2 capacitors would fix the muddiness of the nomad? I did some experimenting took the FX loop out into the FX loop in of another amp. I was floored no muddiness amp was real lively! hmm so the mud is all in the power amp! Well i forum'ed a bit and it's been suggested the capacitors on the PI's load is the source of mud!. As soon as i get a chance i'm going to remove them.
I've already done a bias mod and fx serial mod.
Randall RM100 & Mesa Mark V
2x12 Recto & 1x12 Widebody ported.
Epiphone Z.W. bullseye Les Paul,
Epiphone limited edition Midnight Les Paul
Line 6 M13
 Post subject: Re: nomad mods
PostPosted: Wed May 27, 2009 4:55 pm
If you could say that I might be convinced to keep mine! That's the major reason I'm lookin to lose mine. I'd love to hear all about all the mods for the Nomad. [in one place, maybe a *cough* Nomad subforum?]
-dave
Carvin DC200 - American Strat - Mark 5 - Traditional 4x12
PostPosted: Wed May 27, 2009 5:35 pm
When i get a chance to do it I will photo doc it.
Line 6 M13
PostPosted: Wed May 27, 2009 10:08 pm
Any way to post before and after .wav files with the same eq settings?
Thanks for raising this. There is something odd about the power amp section of the nomad: When I run a outboard preamp into the effect return loop, the sound is very very different (and not good), compared to when I use my Heartbreaker power amp with the outboard pre.
However, I don't have any major complaints with the way the nomad's preamp works with the power amp...
Here's a test I'm going to try: I'll take the effect loop out from the nomad and run it into the Heartbreaker's effect return and see how the nomad's preamp sounds with the HB's power amp.
If that works out, its a simple matter to mod the nomad to the HB specs.
PostPosted: Thu May 28, 2009 7:21 am
the heartbreaker has the cap on one of side of the PI anode.
Line 6 M13
PostPosted: Thu May 28, 2009 6:35 pm
Well, I would be very interested in any power amp mods (and other mods) that would fully remove the mud. Please post as you experiment.
Genz Benz El Diablo 60 TS head
Bugera V22
Carvin SH 225
Carvin DC 120
Epi '56 Les Paul Goldtop P90
Electra Phoenix X189
Custom Strat
'61 Gibson Les Paul SG Standard
Many others
PostPosted: Thu May 28, 2009 7:57 pm
hopefully i'll get to it soon, i know i can do i monday
Line 6 M13
PostPosted: Thu May 28, 2009 8:01 pm
Do a tutorial on the Bias Mod!
Schecter Guitars | Kemper Profiling Amplifier | Superior Drummer | REAPER
Videos: http://www.youtube.com/fluff191
Tunes: http://www.blackmetalbicycle.com
PostPosted: Thu May 28, 2009 8:21 pm
will do, just need to take a pic and show the schematic change. Doesn't require removing anything just putting a trem pot over the bias resistor already there.
Line 6 M13
PostPosted: Thu May 28, 2009 9:40 pm
And the FX Loop mod! Please? :D
PostPosted: Fri May 29, 2009 4:46 pm
Well. a trim pot would make the mod adjustable, right. And please make the pics and diagram so that I can show it to a tech and have him understand what we are doing here. I'm not good enough at this stuff to do it myself.
Bugera V22
Carvin SH 225
Carvin DC 120
Custom Strat
Many others
PostPosted: Mon Jun 01, 2009 10:20 pm
Well i mod'd my amp today and wow took all the mudd off channel 3, didn't thin the amp out at all either. Made it so i don't have to use my sonic stomp to enjoy the amp. Now it didn't turn the amp from a dark amp to a super bright amp just took the mudd away. Making the amp bright will require a presence mod on the power amp. The presence controls on the individual channels r basically a high frequency dump to ground. A true presence control is part of the NFB in the power amp.
here is a pic of what i did today the caps marked in red r the ones to remove.
Line 6 M13
PostPosted: Mon Jun 01, 2009 10:30 pm
Real simple mod see the sharpie slashes? ok say the side with 3 slashes is pin 3 and the side with 1 slash is pin one. Remove all the wires from the pot, then solder together the wire from pin 1 and 2 and insulate. Then just insulate the wire from pin 3.
Line 6 M13
PostPosted: Mon Jun 01, 2009 10:32 pm
i would appriciate if someone would take pic of there unaltered nomad insides. i forget how some of the wires were routed and isolated from each other.
Line 6 M13
PostPosted: Tue Jun 02, 2009 8:50 am
I can take some virgin nomad pics when I get home tonight, since you were so nice to share those mods with us. Maybe I can do before/after pics/clips too! [we need a smiley that's tenting his fingers like Mr. Burns!]
-dave
Users browsing this forum: Google Adsense [Bot] and 16 guests
