Mesa Boogie Forum
It is currently Fri May 24, 2013 6:58 am
 Post subject: Slave
PostPosted: Wed Mar 18, 2009 10:01 pm
Last weekend I hooked up from the Slave on my Stiletto back panel output to an amp that has a "power amp in" jack. The Slave level controlled the volume of the Slaved amp. All I needed to do to the Slaved amp was to power it on, no control over any of it's on-board control; volume treb, mid, bass etc. :?: Question is: if I wanted to slave say, a combo or head/cab setup that DO NOT have a "power amp in" jack, do I just simply plug into the input jack of the Slaved amp:?:
Thanks, Tom T.
Mesa Engineering
-Mesa Stiletto Trident Stage 1
-Mesa 4 X 12 Recto Slant Cab V-30's
Other-
"And the neutered Jackals slink about who only disgorge carrion from their mouths in a feeble attempt to say something intelligent".
 Post subject: Re: Slave
PostPosted: Wed Mar 18, 2009 10:47 pm
Thanks, Tom T.
You can, but you need to keep the slave out volume extremely low as you're running through the slave amp's preamp and it'll get overdriven hard if you send anything higher (it'll be similar to overdriving your amp with an OD pedal, except your doing it with another amp's preamp).
You can also plug into any FX loop return... though I suspect you may already know that.
PostPosted: Thu Mar 19, 2009 9:17 am
If you go into the preamp section of your second amp, set it up for a clean tone and it will work otherwise you have one preamp feeding another. I prefer to run into the effects return on the second amp when I do this. If the second amp has an effects return. This will ussually disable the preamp of the slaved amp and your master volume will be the only control you have.
Triple Rec 3 Channel Recto Straight 4x12
Sunn Model T Laney 4x12 (Too Damn Loud)
Subway Rocket
Gibson Les Paul 1960 Classic Reissue
Gibson Les Paul 1972 GoldTop
Fender USA Strat
PostPosted: Thu Mar 19, 2009 5:18 pm
screamingdaisey, JW123,
Thanks for your help. Will carefully try each scenario.
TomT.
Mesa Engineering
Other-
PostPosted: Sun Mar 22, 2009 5:58 pm
Effects loop return is just another term for power amp in, so it's technically the same thing.
You shoud avoid running a line level signal out of the slave into another amps input. The slave knob adjusts the strength of the signal. So it's essentially there to match that output with another input, so level-wise, when keeping it really low, you should be able to match it with another amps guitar input (which is designed to suit a guitar signal, which is much weaker than a line level signal). If you have the slave out control too high in this scenario, you'll experience clipping (like with a boost pedal, which essentially does the same thing).
I'd try and use the seconds amp master volume to control the overall volume, and use the slave out control to simply match the levels. And if possible, try to use the power amp in/effects loop return, as the signal will be least colored this way. Any additional preamp tube ciruit will color the tone, set clean or not. And most tube preamps have four or five, so go figure.
The slave is designed to work with line level inputs as well, so a power amp in/effects loop return is the way to go. :wink:
- Mesa/Boogie Lonestar Classic 1x12 Combo
- Mesa/Boogie Mark IIC+ Export Model w/ Simul-Class, EQ, Reverb and EV-12L Speaker (Head and Thiele cabinets custom-made by GTS)
PostPosted: Sun Mar 22, 2009 10:30 pm
What I am wanting to try is using my slave out into effects like delay/vibe/chorus into slave amp. Will it work like I think?
Tastes like Condor.
Users browsing this forum: Google Adsense [Bot] and 3 guests
