Slave out->fx->par.loop return= SERIAL LOOP!??
andershoeg
Denmark
Hey! I was just thinking, that if you took the dry signlal out from the slave out of (i.e. my single recto) an amp, go through the like flanger phaser, etc., would this function as a serial loop, or am i just forgetting something!? I am not near my amp, therefor im asking! Thought it would be a fantastic idea if it works!? Anyone knows!?????
B.R. andershoeg
well........did take a look in the manual.......it's not possible :-( , cause if you do it, you will create a feedback loop. ****...... :-(
If you want really bold effects, and dont mind using a mountain of gear, you could run the slave out thru your fx and into a stereo power amp and more cabs. That way you can use huge chorus/flange type fx and wide stereo echoes without getting washed out in the overall mix, as the master amp is completely dry and maintains punch. My previous live rig was set up like this with excellent results.
