Casters for Rectifier 4x12???
hazmat33
Y-town, Ohio
I tried doing a search but it said that "casters" was too broad of a term.
I picked up a newer 4x12 angled Rectifier cab on the used market. It did not come with casters.
What size do I need? Is there a cheaper alternative to the Mesa factory casters from maybe an industrial supply store like Grainger?
thanks for your time,
Matt
Matt
www.reliablehardware.com
I recommend the big blue wheels . Much nicer than the stock mesa casters
Im assuming you are referring to the plate that attaches to the bottom of the cab ? You may have to drill new holes but the big blue wheels are much nicer than the sandard mesa caster . They roll much easier . You can also get them with a brake on them as well . I have these wheels on all of my road cases
I’m bumping this back up because I need the exact plate size and wheel diameter for the recto cab. Hardware is already installed just need the casters to slide into.
Yup, these were an exact fit.
https://www.grainger.com/product/16D123?RIID=57751751575&GID=&mid=OrderConfirmation&rfe=087dea7b7b43bf8e159e5f812981f8f2a6c9b14bb2fcbbd30bb5fa26ef45ceb6&gucid=EMT:10339122:Item:CSM-323&emcid=NA:Item
