'Flabby/Muddy' Bass on the Lonestar? Want to change it?
Charles Reeder
This is about another Lonestar Modification that I ‘stumbled across’. Yeah, I do seem to stumble a lot.
Once again…as I stated (over and over again) when I posted my Lonestar Channel-2 mod; if you are perfectly happy with the sound of your amp ‘as-is’ then for goodness-sakes’ leave it alone! Nobody is trying to convince you that you need the mod…if you ‘need’ it…you’ll know it!
There frequently arises talk about the Lonestar having ‘flabby’ or ‘muddy’ bass…and I think there is a certain amount of truth to that. I love the sound I get from my Lonestars…but I kept thinking it would be nice if I could get rid of some of the ‘flab/mud’. With the gain up rather high on either channel…when playing some low notes… there seems to be too much loss of definition in the bass…even more so than with the midrange and high notes. Well; I didn’t go looking for a way to solve that but I stumbled across one.
I have a Fender Hot Rod Deluxe…and many people have the same complaint about the bass on the HRD….that it is ‘too flabby’…that it ‘muddies’ things up. There is a site for modding the HRD. http://studentweb.eku.edu/justin_holton/bias.html.
If you go to that page you will see a section for ‘modifications’. I clicked onto the ‘James Vanden Berg Mods’ http://studentweb.eku.edu/justin_holton/jvmods.html.
Once there I found the following description of the Hot Rod Deluxe’s flabby-bass problem and the simple mod that fixes it. The following except is the midrange tone pot mod from the ‘James Vanden Berg Mods’ on the ‘Unofficial Fender Hot Rod Deluxe’ site:
(Remember the excerpt below is talking about the Hot Rod Deluxe…It seems almost as if they are describing the bass on the Lonestar!)
TONE CONTROL MODIFICATION TO BETTER CONTROL BASS RESPONSE
Why does this amp sound so flabby in the low end? Part of the reason lies in the speaker/cabinet combination. I’ve plugged this amp into other speakers to compare and found that the stock speaker/enclosure seems to really favor the bottom end, particularly for a 1-12 combo. This is great, because it means that the speaker and cabinet are very efficient for these critical lows, and if we can control the amount of bottom end the amp sends to the speaker, we can get great volume without working the amp too hard. The problem lies in the tone control section. I compared this circuit with other vintage Fenders, and the most critical difference is in the way that the Midrange control is wired. If you look at most of the older designs with a midrange control (such as a vintage Twin Reverb), the Mid control is wired with the wiper tied to the high side of the pot, just like the bass control. This effectively turns the potentiometer into a variable resistor (a variable resistor is a 2-terminal device, whereas a potentiometer is a 3-terminal device that is used as a voltage divider, as in a volume control). On these amps, you can turn the volume all the way off by turning all the tone controls to 0. This then allows you to more precisely balance the lows and highs coming through the tone circuit.
The Mid control on this amp is a 25kA pot. (“A” stands for audio taper). Thus, the stock circuit in this amp puts 25,000 ohms at all times between the bottom of the bass control and ground. On vintage Fenders without a mid control, the resistor in its place was usually only 6.8k. On models with a mid control, such as the Twin Reverb, the pot was only 10k, so even with the mid turned up all the way, it didn’t have the same low-end response as the stock circuit in this HR Deluxe. The larger the value of this midrange resistor, the more bass and low-mid the amp has, regardless of the setting of the bass control.
Have you ever seen a “Loudness” switch on an older stereo? The Loudness circuit boosts the bass and treble and is intended for low-volume situations to compensate for the fact that the human ear hears midrange frequencies (where most speech resides) more acutely at low levels than deep lows or high trebles. As volume increases, this effect reduces. If you play a stereo at high volume with the Loudness switch engaged, it can sound flabby because the bass frequencies are now over-amplified for our ears. This is precisely what’s happening with this Fender HR Deluxe. It sounds great at low levels, but the bass overwhelms the tone at higher volumes.
Justin's comments: Instead of using wire I took a small piece of solder and melted it into place. This creates a very unobtrusive jumper that's easy to remove. Be sure to test your jumper with an ohm meter to make sure it passes current.
Fixing this takes very little effort:
Follow steps 1 and 2 above. Solder a jumper between the left and middle terminals of the mid control (when facing the amp from the rear, as you would be when working on it). That’s it. You can now reverse steps 1 and 2 and try it out. If you did it right, you should now be able to turn your volume down to 0 by turning all of your tone controls to 0. More importantly, you can now dial in just the right amount of low end with the mid and Bass controls. Remember, they’re interactive. The higher you set the mid control, the more bass you will get.
END of Fender Hot Rod Deluxe MOD excerpt.
NOW BELOW: THE RESULTS I OBTAINED ON MY Fender Hot Rod Deluxe AND MY Mesa Boogie Lonestar:
Well I tried the mod on my Fender Hot Rod Deluxe…and it worked…very-very well
So, I started wondering if the Lonestar would benefit from a similar mod…and... could a Lonestar even be modded that way? Finally a few days ago I opened up my LSC Head and checked out the ‘midrange’ pots.
On the Fender HRD mod; the center contact on the pot is jumpered to the contact on the left. That is because on the HRD; the pot is mounted to the circuit board from the top…upside down… (So the contacts are facing down).
The Lonestar has ‘flying-leads’ and the pots are mounted with the contacts facing upwards. So with the Lonestar…I needed to run a ‘jumper-wire’ on the midrange controls on both channels FROM THE CENTER CONTACT TO THE CONTACT ON THE RIGHT. This has got to be the easiest ‘mod’ I’ve ever done! It is necessary (on the Lonestar) to do it to 2 midrange pots (unlike the HRD which has only one midrange)…but it was still easier because I had to partially remove the circuit-board from the HRD in order to do the mod on it.
I REPEAT: All the mod involves with the Lonestar is soldering a ‘jumper-wire’ from the middle contact of each midrange control to the contact on the right. (The middle and right when viewed from the back of the amp)
With the Lonestar; I only had to remove the midrange pot for Channel-1 in order to gain access to the pot on Channel-2… by being very careful I didn’t have to remove the Channel-2 pot. I carefully heated the center contact with my soldering-iron and pressed a very slim wire into the hole next to the gray wire already there. The contact on the far right has nothing soldered onto it; so there was no problem at all soldering the ‘jumper’ wire to it. Once Channel-2 was done; I put Channel-1’s midrange pot back in and soldered the ‘jumper-wire’ to it. I reassembled the amp and proceeded to try it out.
Wonderful ‘tight’ bass! There is still plenty of bass on tap…but it doesn’t ‘muddy-up’ the other frequencies and it retains definition longer even with the gain up. I A/Bd the modded head against my LSC Combo to make sure I was really hearing the dramatic improvement that I thought I was. It was a definite improvement. Within the hour I had modded the combo too.
Stock; the Lonestar almost seems to be pushing some ‘sub-bass’ with very low frequencies that are almost inaudible…and that bass seems to ‘leech’ power from other notes as well as ‘bottoming-out/muddying’ the audible low notes. This mod seems especially useful when turning up the gain on channel-2…but it definitely helps both channels. Don’t worry…the LSC still retains PLENTY OF BASS!
NOTE: I had serious doubts about whether this mod would actually do anything useful for the Lonestar…so I ‘hedged-my-bets’ and used long sections of wire with ‘dpt’ mini-toggle-switches attached for the test on the first Lonestar. That way if I didn’t like the effect of the ‘mod’ I could merely ‘turn it off’…without having to immediately tear the amp down to remove it. I let the wires with the switch ‘dangle’ out of the chassis for the test. Now, I can either remove the toggle-switches or find a good place to mount them…when I feel like it. I may actually keep the toggle switches in the circuit as that gives some more versatility. You could do the mod with toggle-switches attached too...in case you are unsure about whether you will like the mod. Then by 'flipping the switch' you can conduct your own A/B comparison test.
REMEMBER: Always be super careful when doing ANY work inside an amplifier! Dangerous High Voltages Inside! If doubtful get a professional involved!
I don’t know if ‘flabby/muddy’ bass’ is an issue with you or not; so I don’t know if you will be motivated to try the mod,…but I figured I’d tell you about it as a possible solution. YOU decide if you need or want it…based upon YOUR experience with the amp…NOT MINE or anyone else’s.
Cheers: Charles
Here we go again... :lol:
Considering your past track record, Charles, I'm gonna have to try this one out as well. I just had to leave my LSC behind for a while though because I'm heading back to the States to meet my brand new daughter. I'm sure the other guys will try the mod and post up a storm. I'm looking forward to reading that stuff until I can give it a shot on my own.
Would this mod work on a Rectoverb combo as well? A switch would be cool too, but I don't really like the idea of drilling a hole in the front of my amp!
Hi Charles. What about this design allows for more precise eq tweaking? Is it just that there is more range across the tone controls? Just wondering. I'm more of a player than I am an amp tech......and that's really not saying much at all! :?
Hey "MusicManJPG"
You know; I wondered the very same thing! I know I've read numerous posts about 'flabby' bass on various amps...and people's unsuccessful attempts to 'dial-it-out'.
I want to be very clear about this...I am no amp tech...and I know precious little about electronics...but it seems to me that if the midrange controls on a 'Rectoverb' (or just about any other amp) are set up like the midrange controls on the Lonestar; then this simple non-obtrusive mod should work,
You'll just have to 'pull-the-chassis' and take a peek. If the mid controls are as described on the Lonestar; you could give it a try. The very worst that could happen is that it won't do much of anything to help...it won't blow up the amp! If it works...GREAT...if not...simply undo the mod.
Sorry I couldn't give you a better answer than this.
Charles
OOPS!
Forgot to mention. I don't like the idea of drilling holes either (at least not on the front of the amp).
If I can find a space on the underside of the chassis that has ample room; and can be reached easily...I'll probably put the toggle-switches there. I just haven't gotten around to looking in earnest yet.
Charles
Hey lyman:
Those words are not mine...but belong to the person who posted the mod for the Fender Hot Rod Deluxe. That's where I encountered the idea for the mod... so I am not really qualified to answer. What it 'seems' to do...is make the bass more 'tweak-able' because the midrange control limits the bass as well as the bass control. As the HRD site poster comments...this is how many of the 'Classic' Fender tone controls were set up. Since Mesa originated by 'hot-rodding' Fenders...it's rather likely that the Lonestar would benefit from a Fender type tone-control setup.
Charles
Congratulations on your new Daughter!
I think you'll like the mod. It isn't hugely 'IN-YOUR-FACE' noticeable like the Channel-2 mod is but it does indeed help (rather more sublimely). The great thing about it is that it is so easy to do...(and to undo) if that is desired.
Charles
OOPS!
Charles
Thanks for the reply! Still wondering if it might work on a Rectoverb... :wink:
This sounds really interesting.
There is precious little room on the bottom or back of the Lonestar chassis. You might be better off with Push-Pull pots. This way your amp is completely reversible and the controls are still on the front of the amp.
Ooooooo! Good idea Monsta!
Thanks. I'm 0-2 on being home for births.
I like Monsta-Tone's idea of a push-pull setup on the front of the amp. That would be ideal, but in any case this mod couldn't be any simpler to reverse if I don't find the change useful.
Do the benefits only show when the amp is playing at stage volume?
Does it sound neutered at lower levels on 10W?
I run into flabbiness when I'm really pushing, but the bass is balanced and full at moderate volumes on the 10W setting.
I've always thought that the 'flabbyness' is characterictic of the C90 speaker.
I can't really comment on the effect of this 'mod' on the 10-watt setting; as neither of my Lonestars has it.
The effect of the 'mod' definitely shows up more at higher 'pushed' volumes. That is where it's true benefit comes into play ...in my opinion. It is barely apparent at very low volume. It is certainly noticeable at moderate volumes by someone very familiar with the sound and response of their amp...but it really helps and 'comes-into-play' at higher 'pushed' volumes.
I have several cabinets and speaker 'setups'...including EVM 12 L and Eminence Wizard...and the 'flab' was there in all of them...although of course the EVM handles it better than any of the others.
Charles
Hey MusicmanJPG:
My earlier reply was perhaps not precise enough. If you will remove the chassis from your 'Rectoverb' and checkout the 'midrange' controls...you should be able to see if it is a 'candidate' for this mod (or not).
Just checkout the wiring on your midrange control pots...if the contacts on the right are empty of any wiring...you're good to go...just 'jumper' a wire from the center contact to the empty contact on the right.
How much effect this will have on your 'Rectoverb' is anyone's guess...but it will not hurt it to try it. The 'mod' is easily done...and even more easily 'undone'...merely 'clip' the connecting 'jumper-wire' in the middle.
If it does indeed help...perhaps you might then consider posting your results under 'Rectoverb' mods...and help out other Rectoverb users. I imagine many of them will never read this thread.
Regards: Charles
I like this suggestion.
But of course to really evaluate the 'mod' itself we would have to be certain to use pots with the same 'resistance' and 'taper' as the original 'stock' pots.
And that brings into consideration the possibility that pots with a different value of resistance might work 'even better' with the mod. From reading the Fender Hot Rod Deluxe post (that I included in original post) it is apparent that Fender used different values of midrange pots in different amps to 'fine-tune' the bass response.
You seem to do a lot of modding and I assume might have some parts on hand. I would love to hear about any results you obtained from substituting different value pots.
Regards: Charles
:D :D I have 2 of them in my DC-10 combo and I do not have a problem with this amp being flacid. Sometimes I wish there was a little more breakup from the speakers.
Gonna have to give this one a try! Maybe next week. I'm going on vacation tomorrow.
Hey MusicmanJP6:
Regards: Charles
Thanks Charles! I'll take a look this weekend and see if it can be done...
