Doc wrote:
Hi everyone,
This is my first post and I'd like to ask about hooking up two Mesa
3/4 back 1x12's with my Stiletto Ace combo. Right now I have one
sitting under the amp with cab & combo plugged into the 4 ohm speaker
connections. How can I connect my other 3/4 back?
The additional speaker added a little girth to the sound and I like to
maximize this effect as my other speaker is not being used.
Thanks in advance for any suggestions.
not sure its built for 3 cabs (1 being your combo)..... can the 3/4 cab you have daisy chain to the other 3/4 back cab? if you can you can hook up the combo's speaker to the 4 ohm out and the first 3/4 back cab to the 8 ohm out for a safe mismatch..... other than that the transformer wasnt built for 3 cabs (or at least i dont think it is).... another option is to get a power amp (say a 20/20).... slave out to the power amp and the power amp to your extra cab.... and that there would get you a stereo setup if you desired
On another note i'm not sure what that extra cab is going to get you..... if your looking to push more air or add some more girth to your sound i'd recommend selling both your 3/4 backs and either look into a 2x12 3/4 back cab or something like a 2x12 stiletto cab or a rk 2x12 cab.... again its just a suggestion but at least you'd use a safe match with your combo and it would make it a lot easier in terms of hookups and portability
