Stupid Hotplate Question
CudBucket
Just got a Hotplate off Ebay. It's in mint condition. I don't have an extra speaker cable to connect it with but I'll pick that up today.
What should I do to ensure that it works properly? I know this sounds stupid but I'm just asking so I can be sure.
Thanks.
Dave
Basically, just hook it up, and crank the amp, turn the knobs. It's pretty simple. On the -16dB setting, the knob on the right will adjust the volume. On every other setting, it will do nothing. Just mess with it, and you will know if it works or not.
Make sure you get a really good speaker cable to connect the amp to the Hotplate. The danger is the wire becomes the attenuator and causes your transformer to blow. Just get a good quality and appropriate guage speaker wire for your amp.
Ned
