It is currently Wed Jan 17, 2018 2:14 am
Post new topic Reply to topic  [ 14 posts ]
 Post subject: Roadster Schematic
PostPosted: Sat Nov 07, 2015 7:21 pm
Trying to find a Roadster dual rectifier schematic. - Any clues? - I've tried doing a search - all I've found so far are 3 channel dual rectifier schems.
Thanks ahead of time.
 Post subject: Re: Roadster Schematic
PostPosted: Mon Nov 09, 2015 12:36 am
I'm interested too! It's about time I try to learn something about me amp!
PostPosted: Mon Nov 09, 2015 6:41 pm
What part are you looking for? Perhaps one of us other roadster owners could take pictures of our amo internals and share it?
Also, part of the roadster and roadking should be similar to the regular dual rec. Lots of the trick stuff is switching logic.
Roadster, Mark IV, Electra-Dyne, Traditional/ Stiletto 412
Gone: Quad MIDI Pre, TriAxis V1 & V2, Formula Pre, 2:90, 20/20
PostPosted: Sun Nov 15, 2015 9:41 pm
I would imagine the Roadking will be similar. Don't have a particular problem yet - just trying to be ahead of it in case I have one. Hopefully I wont need it.
PostPosted: Mon Nov 16, 2015 2:52 pm
I have it all memorized in my head. What do you need to know?
PostPosted: Sun Nov 29, 2015 9:33 am
Considering how the main changes between the two are primarily power amp and output switching options, I would have to believe the Roadster is nearly identical in regards to preamp, PI, and one FX Loop with the Road King. The power amp itself is probably really close. Since it can run as 6L6 only, that configuration is likely the same. The switching will be what is most modified on the Roadster.
Otherwise, all the modes on all the channels are there. Look at a Road King schematic and see.
My Humble Music Tech Blog:
Dual Rectifier Index
PostPosted: Sat Apr 02, 2016 11:10 am
Any luck? I've been looking everywhere. Still can't find one.
PostPosted: Sun Apr 03, 2016 11:47 am
I'm still not seeing it. I know some hard to find schematics can be found on Russian/Eastern Euro servers, but accessing those are like playing viral Russian Roulette with 3 in the cylinder.
PostPosted: Wed Dec 14, 2016 10:27 am
Still looking, Has anyone had any luck?
PostPosted: Mon Feb 06, 2017 3:11 pm
There's a Road King II Schematic at The Tube Store:
http://www.thetubestore.com/lib/thetube ... ematic.pdf
For a Roadster, just take this schematic without the Prog. Linkage, Switchable FX Loops, and Switchable Speaker Outputs.
The Progressive Linkage uses relays RYA, RYB, and RYD. The Switchable Speaker Outputs use relays RY4 & RY8. Most of the JFETs in the FX Loop are for the Switchable FX Loops.
Mesa Electra Dyne Combo
PostPosted: Tue Feb 07, 2017 3:06 am
hey, I received all the boogie schematics from Tremoverb over any other Recto to MarkV directly from mesa by simply contacting them. Apart from the switching architecture, the values of the parts are the same on the DR TR Roadster or Roadking - And we all know those amps sound and feel very different. What ever it is what makes them different, it is not written on the schematics - it is the PCB itself. The boards sound all different.
PostPosted: Fri Apr 21, 2017 12:46 pm
Anyone have any luck yet. Been having some issues with mine and the nearest service center is 200m away
PostPosted: Sun Apr 23, 2017 5:47 pm
https://www.youtube.com/watch?v=4kNMtOmT76U
He shows the schematic when explaining the repair. He never shows the last page of the switching circuit though.
Mark III Purple Stripe Combo S/N 18783
Dual Rectifier Rack Rev.F S/N R-001082
Triple Rectifier Rev.G S/N R-006420
Trem-O-Verb Combo S/N R-04706
Triaxis S/N T0265
2:90 S/N N-1573
ADA MP-1, Peavey 5150 Combo, DIY Slo 100, Line 6 Vetta Comb
PostPosted: Mon Apr 24, 2017 7:48 am
Great video. Thanks
Users browsing this forum: No registered users and 8 guests
