TC-100 inbound - HD500 Midi?
nitrous12
Been a while since I've posted here. I have a TC-100 coming soon and would like to set it up with my HD500 and have the HD control channels, solo, reverb, etc.
I haven't had a midi amp in some time but seem to recall it is fairly easy to setup.
Is anyone running a TC with an HD500? Anything special I need to know? Thanks in advance.
It's crazy easy with the TC-50.
Just set the channel, fx loop, reverb on the amp the way you want it (I'm assuming fx loop "on" to use the hd-500 effects), pick the program you are gonna use on the hd-500 (say "1" for instance). Then there is a "midi switch" toggle on the back of the amp. Hold it up for a second. The red light beside the switch will flash.
Boom. You just programmed the amp for program "1" on the hd-500. Now just put in the effects you want on the hd-500 and that one is done. Now repeat that process for "2" on the hd-500.
Easiest set up ever.
