I’m guessing that the combo chassis can simply be mounted to the straight front Mesa rackmount frame without issue. Only thing being the reverb tank, naturally. It would be oriented the same as my Electra Dyne rackmount.
Can anyone confirm?
Converting a TC-50 combo to rackmount
Mark III (red stripe)
Mark IV B
Electra Dyne
rackmount FTW
Mark IV B
Electra Dyne
rackmount FTW
Re: Converting a TC-50 combo to rackmount
Hey, riggles. I own the rack version with a Line 6 Pod HD Pro X for processing and I can tell you there is absolutely no room for the reverb tank in an SKB 6 space shallow rack 1SKB-R6S so I don't even connect it. I don't need it with all of the processing power in the Pod. Without the tank everything is a perfect fit, light, transportable and the front and back are gasketed to keep the moisture out.
I'm sure it's a simple transfer from combo to rack but a call to Mesa Boogie would help. They return all calls and emails and should be the same day. I've talked to them a few times and discussed my TC-50 through repeated emails.
